November 20, 2025, 03:18:49 AM *
Author Topic: INSTALLING NEW PILOTSCREWS + O-ring + washer + spiral = advice please ?  (Read 2326 times)
FLATSIX
Heist o/d Berg BELGIUM
« on: September 06, 2009, 12:43:00 PM »
Hello,
I ordered new pilotscrews. They come as a set : screw + spiral + washer + O-ring.
I will take off the chrome intakes so that a have more space to take away the damaged pilots + re-instal the new set.
Is it a straight-forward job : any advice or things that I should know before messing it up again?
Thanks for your help. Cheesy cooldude
standard '97 - european F6C - red & white - 27.000 KM
« Reply #1 on: September 06, 2009, 02:04:56 PM »
I trust you have the D shaped pilot tool. It should be very easy. Make sure when you put the new ones in, you LIGHTLY seat them before backing them out to your final setting. I put a bit of Never Sieze on the threads so they don't get frozen in after a couple of years.
valk2128
Suwanee, GA
« Reply #2 on: September 06, 2009, 02:38:02 PM »
It's a good idea to place a piece of tape (the blue painters tape works great) over the intake hole on the engine after you remove the chrome intakes.  This will keep anything from falling into the engine (dirt, ...).
PeaGoody
« Reply #3 on: September 06, 2009, 05:04:48 PM »
I just did a carb rebuild a few weeks back and found a suggestion to dip the O-rings in Sea Foam prior to installing.  It helps to make sure the O-rings seat correctly.
Misfit
Colorado Springs Colorado
« Reply #4 on: September 06, 2009, 06:12:53 PM »
Do not take all of the intake runners off at the same time so that your carbs wiil have some support.
« Reply #5 on: September 06, 2009, 07:24:28 PM »
only O-ring grease should be used for installing o-rings, which is basically silicone grease, also known as di-electric grease.
the seafoam god should not be used in this case.
FLATSIX
« Reply #6 on: September 07, 2009, 08:40:03 AM »
Thanks for the good advises.
The O-ring : I take the neww-one and put it on the old and damaged pilotscrew and turn this all the way in till seated, then take out the old pilot and carefully screw the new pilot (with spiral and washer) till lightly seated.
Is this O.K. - or do I simply put the new O-ring in the hole and push it with something slightly tinner than O-ring outside to the bottom of the hole - then install the new pilot + spring + washer.
How do you folks do this the best??
Sodbuster
« Reply #7 on: September 07, 2009, 12:03:51 PM »
So .... any tips on where to get that D-shaped pilot screw tool ??
VRCC # 30938
« Reply #8 on: September 07, 2009, 04:30:06 PM »
just install the new assembly, washer btwn spring and o-ring and of course lightly seat it.
roboto65
Conroe,TX
« Reply #9 on: September 07, 2009, 04:58:47 PM »
Motion Pro cooldude
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
Sodbuster
« Reply #10 on: September 07, 2009, 05:59:30 PM »
Motion Pro cooldude
That bit from Motion Pro looks to be a little short .... did you have to mod it at all to make it work ??
VRCC # 30938
Misfit
« Reply #11 on: September 08, 2009, 07:32:32 PM »
Motion Pro cooldude
Just put it in a 1/4" socket. Shallow = short handle deep well =long handle.
Sourdough
Tucson
« Reply #12 on: September 08, 2009, 07:44:13 PM »
Just bought one from Redeye tech for about $7.. hope this is what I need
01 I/S Black/Beige
97 Standard Bumblebee
Sodbuster
« Reply #13 on: September 08, 2009, 07:48:11 PM »
So can I assume that the bit will be long enough to stick out of the carb ??
VRCC # 30938
roboto65
Conroe,TX
« Reply #14 on: September 09, 2009, 05:15:20 AM »
You assume right it can be a tight fit but it will fit just have to make sure you are on the D shaped screw it only goes one way of course but finding it sometimes is a pain LOL
Allen Rugg
VRCC #30806
