February 11, 2026, 12:14:07 AM
Poly shock bushings
Topic: Poly shock bushings (Read 1607 times)
Yfx4
North of Dallas TX
Poly shock bushings
September 14, 2015, 05:52:06 AM »
I am planning to replace the stock shock bushings with poly ones.
A quick search showed these :
http://redeye.ecrater.com/p/18385698/rear-shock-bushings-polyurethane-teflon
Is there a better source?
1999 Valkyrie Interstate
2007 VTX 1800R
DW rides a 2010 Spyder RT
Ramie
2001 I/S St. Michael MN
Re: Poly shock bushings
September 14, 2015, 06:31:37 AM »
You can get them through any Honda dealer but they usually have to order them.
“I am not a courageous person by nature. I have simply discovered that, at certain key moments in this life, you must find courage in yourself, in order to move forward and live. It is like a muscle and it must be exercised, first a little, and then more and more. A deep breath and a leap.”
September 14, 2015, 07:24:20 AM »
Quote from: Ramie on September 14, 2015, 06:31:37 AM
If you get OEM Valkyrie bushings, they won't be polyurethane... I heard OEM
VTX ones are and that they fit.
I think redeye stuff is always supposed to be good...
Attic Rat
VRCC # 1962
Tulsa, OK
September 14, 2015, 07:51:28 AM »
I use Red eye's poly shock bushing
Yfx4
North of Dallas TX
September 14, 2015, 07:57:16 AM »
Cool. I will get the redeye ones . Thank you!!
2007 VTX 1800R
PAVALKER
Pittsburgh, Pa
September 15, 2015, 07:08:49 PM »
I think you will find the p ice of the OEM VTX green poly ones much more to your liking...and they are good. If the get the OEM Valkyrie ones, they will be rubber and not poly.
John
wild6
(Old enough to know better)
Vernon, NJ
Reply #6 on:
September 16, 2015, 09:33:44 AM »
Get 4 of:
52489-HN0-671
They're poly and work great.
Last Edit: September 16, 2015, 10:01:12 AM by wild6
“Meddle not in the affairs of the
Dragon
, for you are crunchy and taste good with ketchup.”
