April 29, 2026, 07:29:45 PM *
Author Topic: Part # for switched power  (Read 3185 times)
blackvalk
PARK CITY, UTAH
« on: October 04, 2015, 09:01:16 AM »
There is a funny connector in the right side little box that has switched power. I want to run a USB outlet up front to charge a phone while riding.
Should I buy a matching connector (# please), or just cut the connector off and tap the wires.
OR, just use a 3M wire splice that would be connected before the strange looking connector?
idcrewdawg
Albuquerque
« Reply #1 on: October 04, 2015, 09:05:24 AM »
I will be routing a 12v cigarette lighter that hooks to my battery tender cord that also use for powering my heated riding gear.
Battery Tender 081-0069-8 Female Cigarette Adaptor for Quick Disconnect https://www.amazon.com/dp/B0041CDPQO/ref=cm_sw_r_awd_Vhvewb3F0N4ET
ledany
Paris, FRANCE
« Reply #2 on: October 04, 2015, 01:47:30 PM »
What I asked my dealer for :
« Reply #3 on: October 05, 2015, 03:42:18 AM »
There is a aux connection under the seat in that box that has a 5 amp fuse to it and is switched. I would run a relay with a separate fuse to the battery for the heated stuff. It would also be easy to put in that box the electrical stuff needed to charge the phone and just have a connector running from it. Most phones require 5v like a usb adapter and that can be put under the seat in a bag for water proofing.
hungryeye
Scottsdale AZ & Climax NC, formally freehold, nj
« Reply #4 on: October 07, 2015, 10:45:49 PM »
you can go to cycleconnections.com for the connector, I got one there but have no part number, just take a good look at the plug under seat and scroll down in the Honda section, you will find it easily. another source is qualitycycleparts.com
2014 F6c Red ish
1983 GL650 cream puff
2010 Spyder RS
we DRIVE our cars, we RIDE our motorcycles!
