February 11, 2026, 02:06:19 AM *
Author Topic: Looking for Dyna 3000  (Read 1097 times)
Mulepick
« on: October 05, 2015, 11:49:27 PM »
Looking for a Dyna 3000 for my 98.  Emailed Dyna and an Ebay provider but so far no joy.
Tks,
Bob
« Reply #1 on: October 06, 2015, 03:06:38 AM »
discontinued yrs ago. expect to pay $400 on ebay when one shows up.
see my post for the C5 ignition. I just contacted Paul again a few weeks ago still on the back burner. Not enough interest to push him forward faster.
it would be a much, much better system than the dyna, multi-spark, multi curves and new advanced coils.
I have been using a dyna for yrs.
http://www.valkyrieforum.com/bbs/index.php/topic,79036.0.html
Anthony
Belgium
« Reply #2 on: October 06, 2015, 03:09:22 AM »
i still have one laying around, never been used.
bought it for project, but never installed on my European F6C.
http://www.valkyrieforum.com/bbs/index.php/topic,78942.0.html
contact me via PM if interested.
Anthony
« Reply #3 on: October 06, 2015, 04:56:24 PM »
The Dynas also had problems with going bad and not running well in the 2k range. So even if you get one it may not function correctly. I would just do the interstate icm and use a advance trigger wheel.
rocketray
« Reply #4 on: October 07, 2015, 11:36:57 AM »
If you do as Robert says....don't run in the upper rev's--too much advance but the bottom end will be impressive...
« Reply #5 on: October 07, 2015, 12:58:23 PM »
If the bike is a STD/Tour then I'd recommend the IS ICM.
Bigwolf
Cookeville, TN
« Reply #6 on: October 07, 2015, 01:41:00 PM »
I run a Dyna.  I tried 2 different Dyna units and both would run rough in light loads around 2000 rpm.  It was worse on hot days.  Then I removed the rubber sleeve that mounted the original ICM and mounted one of those same Dyna units to an aluminum heat sink.  It has run well since and has not given another minute of trouble.  Not even any trouble at Inzane 12 which was 105F or better every day.  So, my suggestion would be that if you do happen to find a Dyna, be sure to toss out the original rubber mount and mount the Dyna on something that draws heat away from the unit.
I do carry the original standard ICM with me at all times.  Hey, it is small and the Dyna could still fail.
Bigwolf
Lyle Laun
Calgary, Ab
« Reply #7 on: October 07, 2015, 04:14:53 PM »
Bob:
I've got one that came with a bike but I never installed it. Send me an email if you're interested.
Regards
Lyle.Laun@yahoo.com
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
« Reply #8 on: October 09, 2015, 03:53:10 AM »
the 2k miss, mine does it and I have not used the rubber boot since it was new. funny thing it didn't start doing it until it was 4-5 yrs old. I thought something was wrong with the carbs, coils, spark plugs etc., wasted a lot of time troubleshooting everything.
I always have the oem ICM under the seat.
hopefully the C5 will be available soon. more ignition advance at hwy speeds, part throttle, is a big key to much better mpg.
Blackduck
West Australia
« Reply #9 on: October 09, 2015, 07:20:38 AM »
Not had the 2000 miss, occasionally it runs with weird timing (hear the exhaust really growl and feels flat on acceleration). Just turn  the key off then restart and it resets itself.
ammpro
Clarkdale, Arizona
« Reply #10 on: October 09, 2015, 08:07:41 AM »
C5 is moving forward with a 1500 system. I expect to be testing some components in the next few weeks.
It will probably be worth the wait.
Frank
Have fun. Be safe. Always set a good example.
« Reply #11 on: October 09, 2015, 08:38:01 AM »
Awesome to hear.  cooldude
Thanks for the update
looking forward to getting a finished product.   Cool
bigdanIA
'98 tourer
brooklyn, iowa
« Reply #12 on: October 09, 2015, 10:20:36 AM »
excellent!! i think that it would be money well spent cooldude
