February 11, 2026, 02:06:40 AM *
Author Topic: No clutch.  (Read 1181 times)
srbarclay
Fort Smith, Ar.
« on: October 06, 2015, 06:00:38 PM »
 Last week I cranked up my 98 standard and rode her to work. The clutch lever would not affect the clutch until the last quarter inch before hitting the handle bar. Riding home after work was the same. I had a traffic light at the top of a hill where that I turn. I tried to down shift and could only get to fourth. I limped her home. My clutch has not given me any issues at all. My fluids are good. I changed them last spring. I have no leaks. The clutch lever was sloppy. After researching similar issues on here I ordered the wide blade levers, new pivot bolts and the new brass bushing. The old lever was worn.
 The push rod that sets in the brass bushing came out. Is it lust held in my compression with the brass bushing?
 I installed the new parts today. Then I started the bike, with the clutch lever pulled in, and clicked her into first gear. The bike died. ARGH !!!! I cannot get the clutch to engage. She has 36k miles.
 Any ideas guys?
« Last Edit: October 07, 2015, 03:38:53 AM by srbarclay » Logged
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: October 06, 2015, 06:31:40 PM »
Research clutch damper plate rivets.
« Reply #2 on: October 07, 2015, 02:41:59 AM »
If your personalized picture is a picture of you, I would definitely suspect the dampner rivets.
Not judging you, I like the picture, but that's the kind of action that causes the rivets to go.
I learned that the hard way.
« Reply #3 on: October 07, 2015, 03:20:52 AM »
I never pull wheelies and my rivets went at 41k miles. I have a '98 also and was told there was a bad batch of damper plates provided to Honda, same for the GW1500. search the threads for what to do to replace the damper plate and the two clutch plates on either side.
and there are some '98s out there with over 100k on the org clutch.
srbarclay
Fort Smith, Ar.
« Reply #4 on: October 07, 2015, 03:35:57 AM »
Smiley My pic is not me or my Valk.
I just had to find a cool pic.
Tfrank59
'98 Tourer
Western Washington
« Reply #5 on: October 07, 2015, 06:36:05 AM »
How did you find that picture of me pulling a wheelie! Evil
-Tom
« Reply #6 on: October 07, 2015, 07:29:04 AM »
Probably the first thing to do is bleed the clutch to remove any air.
srbarclay
Fort Smith, Ar.
« Reply #7 on: October 07, 2015, 04:34:49 PM »
Okay. I appreciate that. I will bleed it tomorrow and let ya'll know how well that it does.
F6Dave
« Reply #8 on: October 07, 2015, 06:55:21 PM »
Yes, bleed the clutch.  Your symptoms do NOT sound like sheared damper rivets.  When the rivets shear you can't pull the lever to the grip as it hits a hard stop.
Dorkman
San Carlos, CA
« Reply #9 on: October 07, 2015, 09:53:34 PM »
After installing the parts, did you get normal fluid resistance when you pulled in the clutch, or did it just sink to the grip?  Air in the line will feel spongy.   By chance, was the kickstand down when you dropped it into gear?  Don't ask me how I know . . .
srbarclay
Fort Smith, Ar.
« Reply #10 on: October 08, 2015, 04:15:52 PM »
Today I was at work sitting at my desk on a conference call. The call got boring so I pulled out my phone and checked this site. I read all of the opinions. The idea that someone would have tried to put their Valk in gear with the kick stand down made me laugh. ....... Then I stopped laughing. I think that I had the stand up. surely I had enough sense to have the kick stand up. Did I have the kick stand up?!!
 So..... as soon as I got home I Did put the kick stand up and clicked into first gear. Wallah!!!
 Apparently I had my head up my tailpipe.  uglystupid2
 I thank you all for allowing me to prove that I am an idiot. I appreciate you all and I continue to learn from you all.  Thank you.
« Reply #11 on: October 08, 2015, 06:24:28 PM »
AND iffin it refuses to start have a look see at that big red/orange switch jut ahead of the throttle-it should be in the "run" position!  Roll Eyes RIDE SAFE. Happy? ya figured it out!  2funny
srbarclay
Fort Smith, Ar.
« Reply #12 on: October 09, 2015, 05:32:59 AM »
I deserve that.    Smiley
The initial problem was the lever and brass bushing.
Thank you all.
« Reply #13 on: October 09, 2015, 06:24:29 AM »
Thank you all.
          Most if not all of us have had "brain farts".  2funny kaka happens.  Lips Sealed When we get together on a ride and someone has a problem-you WILL have more help than you can imagine.  cooldude Seen it more than once at the 4 Inzanes I've been to. RIDE SAFE.
srbarclay
Fort Smith, Ar.
« Reply #14 on: October 09, 2015, 03:11:11 PM »
A large Valk ride would be a blast.
Thankk you all
