November 26, 2025, 03:13:19 PM
thermostat?
Topic: thermostat? (Read 675 times)
fiddle mike
Nothing exceeds like excess.
Corpus Christi, TX
thermostat?
October 08, 2015, 01:52:12 PM »
Can someone give me a parts number for a generic thermostat and gasket?
The numbers on the "Generic Parts Page" are invalid, according to the Carquest clerk.
Thnx
Re: thermostat?
October 08, 2015, 02:52:52 PM »
stay with OEM. no benefit for any other. too cold and engine wear goes up and performance and mpg go down.
Re: thermostat?
October 08, 2015, 03:35:08 PM »
33489 Gates # and 13869 is for the stant # bot are for the 195 thermostat just have them look up the 180 number off that. They do also make a 160 in that style thermostat that will also work. 19300-634-812 is also another number again in 195 the application is a 93 Mitsubishi Montero with the 3000 engine in it or also a Honda Civic. Go ask for a 180 thermostat by application and you should be fine.
I must say that I have never seen an engine damaged by running to cool but have seen many that were destroyed running to hot.
fiddle mike
Corpus Christi, TX
Re: thermostat?
October 08, 2015, 03:37:55 PM »
valkyriemc
NE Florida
Re: thermostat?
November 01, 2015, 03:40:52 PM »
I believe Jeff offered an alternate thermostat number, which I changed too when I put new in antifreeze (5/12) and it offered a higher flow rate at the same temp. I noticed a difference and will take any improvement in the cooling department I can get down here in Florida land. My records show Duralast number 15868. Hope this helps, also try search.
Veteran USN '70-'76
=> InZane XXV
