November 26, 2025, 04:26:48 PM *
Author Topic: Reserve Distance - Pingel fuel valve?  (Read 1186 times)
Lyle Laun
Calgary, Ab
« on: October 13, 2015, 08:32:05 AM »
Folks:
Can anyone tell me what the reserve difference is on a 97 Standard tank between the stock OEM petcock and a Pingel ? I remember hearing that a Pingel has significantly less reserve.
Thanks in advance...
Lyle
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #1 on: October 13, 2015, 08:55:31 AM »
Folks:
Lyle
I believe I remember reading that it's about 1/2 of the OEM. However, remember that the total fuel volume doesn't change. It just effectively shifts some fuel to the non-reserve pickup portion of the tank.
« Reply #2 on: October 13, 2015, 08:57:14 AM »
OEM maybe 30ish, Pingel more like 15ish.  However, you still have the same amount of gas/range...just use the trip meter to next fill up.  I start looking for gas at 100miles, and find it before 150miles and never had a problem.
Lyle Laun
Calgary, Ab
« Reply #3 on: October 13, 2015, 10:56:00 AM »
Thanks guys, I knew someone would have the answer - much appreciated
Get out & Ride !!
« Reply #4 on: October 13, 2015, 11:35:35 AM »
I can't answer your question either. I've used a Pingel for at least 15 years and have never hit reserve. I set the trip meter at every fuel up and get fuel by 150-160 miles and it always takes app 4 gal.
« Reply #5 on: October 13, 2015, 04:36:54 PM »
Wasn't there a post about changing the height of the replacement pick up, so you have more fuel on the reserve side of the switch? You might want to do a search.
« Reply #6 on: October 13, 2015, 05:47:20 PM »
Yes, this is what I did to mine, gives me about the same reserve as OEM. Went to a local hobby shop and picked up some fuel line just big enough to slip over the Pingel pickup tube. Laid it next to the OEM petcock, overlapped the extension about a half inch and cut the tube to match the OEM length. Then roughed it up and sweat soldered it like you would a copper plumbing fitting. Been on there for many years with no trouble. Being old school, even though I have a fuel gauge for my I/S tank I still reset the trip meter every time. So far I've never used reserve but its there more for psychological comfort than anything I guess.
valkyriemc
NE Florida
« Reply #7 on: November 01, 2015, 03:22:44 PM »
John, I did the same thing with my Pingel vacuum model some years ago. Still works fine. The only thing I could complain about I guess, would be that Pingels fuel control lever swings to the rear of the bike for the on position. Not particularly intuitive.
« Last Edit: November 02, 2015, 05:18:57 PM by valkyriemc » Logged
Veteran USN '70-'76
