April 29, 2026, 05:10:38 PM *
Author Topic: Made my own running lights  (Read 3540 times)
bscrive
Ottawa, Ontario
« on: October 14, 2015, 06:54:18 AM »
I was going to buy the SoCal running lights, but with limited funds these days I decided to make my own.
I bought some lights off eBay, and made the hardware to mount them.  They are 16W LEDs, so they will throw a lot of light.  All in all, it cost me $40.
idcrewdawg
Albuquerque
« Reply #1 on: October 14, 2015, 07:54:05 AM »
Did you have any difficulty with the connections on the bike side?
« Reply #2 on: October 14, 2015, 08:13:18 AM »
Wow your getting pretty inventive there  cooldude look good and great mod.
ledany
Paris, FRANCE
« Reply #3 on: October 14, 2015, 09:22:42 AM »
Smart idea to cut the exact shape of the lights in the cover instead of cutting the whole square and then invent something to fill it ! I have creed lights I want to install these days, that's a tip I'll follow  cooldude
bscrive
Ottawa, Ontario
« Reply #4 on: October 14, 2015, 10:02:54 AM »
None.  I hooked them up to the wires that Honda put there for running lights.  Green/purple is pos, and green is neg.  I just tapped into the wires.  I didn't use a switch, since I want them on all the time.
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #5 on: October 14, 2015, 07:41:13 PM »
 cooldude dang Brian!  That looks really cool more like mean. It has a mean look to it.   cooldude
BDT44094
« Reply #6 on: October 14, 2015, 10:58:23 PM »
Can you provide some mounting details and photos? Thanks
bscrive
Ottawa, Ontario
« Reply #7 on: October 15, 2015, 05:07:45 AM »
I will try to do that tonight.
I knew I should have taken photos.   Grin
dans2014
« Reply #8 on: October 15, 2015, 06:27:55 PM »
 Wink Great job but I question how much useable light you are going to gain with those. Let us know when you do some night driving if they help
Dan's 2014 Valkyrie
bscrive
Ottawa, Ontario
« Reply #9 on: October 15, 2015, 06:58:56 PM »
I used the three existing mounting holes that are on each side. (see red arrows)
The OE running lights use these same holes.
I used some 6mm bolts that I cut the heads off to hold the bottom bracket.
I screwed them in, and use some nuts to lock them down.
I drilled the holes in the bottom plate accordingly, and then used some more nuts to position the bottom bracket.
I made a bottom bracket to mounted it to these 6mm bolts.
After I got the bottom brackets where I wanted them, I took them off and drilled three 1/4" holes in a triangular pattern.
I did the same with the top plate.
This is so that I can adjust the lights.
I used 3.5"x1/4" pan head bolts, and locked them down with some nuts.
I used pan headed bolts because they were the only ones that were completely threaded in stainless steel.
I put some more lock nuts each bolt, and then put springs on the top two bolts.
The bottom bolt I just put another lock nut on top to hold it solid.
I didn't worry about making it look pretty, since no-one will ever see it, but me.
Here is a picture.
My purpose for these lights is to be noticed in the daytime.  They are 16W LED, and they do put out a lot of light, but our headlights are so bright that I doubt they will be seen at night.
rusty
milaca, mn
« Reply #10 on: October 15, 2015, 07:11:42 PM »
great job! i agree with you about wanting to seen in the daylight. i bought fogs just for the purpose of being seen in daylight. any light i think helps....
peace man
woofred1832
My Valkyrie
northern Ill near fox lake
« Reply #11 on: November 07, 2015, 08:36:47 AM »
                                     Now you got it ...... Like I said in other replys I also, wanted riding lites but the Honda one at $250.00 was just toooo much I did get the Honda switch to put in the left side pannel by the gas cap release,but found lites on the internet for $21.00 each, and they have an extra tiny circuit board that on every third turn on, the lites go strobe..... now thats to be seen, I know I cant ride down the road with them in that mode but for pulling into a parking lot or just a short zap its really cool..Just to have spares I ordered another set,,,and since then I found and got apair of lites that are 3inches in diameter with a, like spot small lite in the center and an outer ring,flood style that can be wired separate, I think I will keep those til someone comes out with a batwing fairing for the 2014 Valkyrie, center head lite and space to mount these to the side...Thats the only other major addition I plan ...... till then I will ride with the windshield,Bags, Hard Trunk(only for trips),hwy pegs,and the driving lites... Thats why I got the Valkyrie,not the FB6, or the full Gold Wing, I set the bike up the way I wanted it,     Ya I do things MY WAY.... FOR MEEEEEEE.
