February 11, 2026, 05:47:44 AM *
Author Topic: Carbs and Ultrasonic Cleaner  (Read 3823 times)
Attic Rat
VRCC # 1962
Tulsa, OK
« on: October 15, 2015, 06:31:52 AM »
I have been noticing that with this new fuel  the carbs are getting harder to clean. After doing so many sets of carbs over 600 sets I keep running into these carbs that the vat will not get clean so I purchase a Ultrasonic cleaner to clean the carbs. Man what a difference it makes with the ultrasonic cleaner. They look brand compared to the harsh carb vat. I have a set of carbs that I did last week and could not get them cleaned. No matter what I did I couldn't get the bike to run on #4 cyclinder. I  put them thru the vat twice but could get them to flow fuel. There is something stopped up internally so I am going to try the ultrasonic cleaner on them when I get time to do so.
« Last Edit: October 15, 2015, 06:35:03 AM by Attic Rat » Logged
BonS
Blue Springs, MO
« Reply #1 on: October 15, 2015, 06:54:34 AM »
The smallest orifices that I know of are the three 0.010-0.015 holes near the butterfly that meter in fuel just off idle. As I recall they're right-angle drilled into the carb body and the access hole is then plugged. I've shotgunned them with cleaner in the past but was never sure that they're unplugged. Do you suspect these or are the other orifices that concern you? I've always been amazed what an ultrasonic cleaner can do with plain water let alone a good cleaner.
« Reply #2 on: October 15, 2015, 07:14:48 AM »
         Gonna recheck that starter button. At this point in time It isn't reinstalled in the housing. Folks like you make this board ROCK!  cooldude RIDE SAFE.
NCGhostrider
Jacksboro, TX
« Reply #3 on: October 15, 2015, 08:40:01 AM »
We use an ultrasonic cleaner on our carb work at the store.  We see a lot of engine driven welders that have carb problems from the ethanol gas.  They work well.
Less mess and less chemicals.
Craig
NcGhostrider
99 I/S
99 I/S
« Reply #4 on: October 15, 2015, 01:23:52 PM »
Hydrocarbons do not do well, trying to dissolve organic substances like fungi and algae, which are
usually the contaminants in ethanol enriched gasoline.
big poppa pump
San Antonio, TX
« Reply #5 on: October 15, 2015, 01:33:29 PM »
I used an Ultrasonic cleaner with Krud Kutter when I cleaned out the carbs on my last build. Worked really well.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #6 on: October 16, 2015, 06:23:05 AM »
Poppa krud Kutter the parts cleaner is what I got to go into my new machine. Trying to find 5.5 gallons is hard to do so I had to make several stores and buy 1 gallon at a time
« Last Edit: October 16, 2015, 06:25:28 AM by Attic Rat » Logged
« Reply #7 on: October 16, 2015, 04:38:51 PM »
How about free delivery on larger orders? Or pre-order the qty required, delivered to your local store for pu.
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #8 on: October 16, 2015, 04:47:27 PM »
I can order 5 gallons but I didn't want to wait
Kid with new toy lol
« Reply #9 on: October 16, 2015, 06:19:43 PM »
5 gallons??  How big is your ultrasonic unit? Mine holds about a half gallon, maybe a bit more. So far I've used plain water and Purple Power at about 25% of the mix. Since I may have to redo the carbs on my 1200 project, I'll probably go with Krud Cutter if I can find it around here. What strength do most of you use with that?
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #10 on: October 16, 2015, 08:01:01 PM »
John make sure you get the one with the gray label that says parts cleaner and can be use with ultrasonic cleaners. I haven't ran mine yet just took out of the box tonight. It is 19.5 long 12 inches wide and 6 inches deep. I can get more than 3 carbs in it at one time. if I position them right I maybe able to get all 6 in at one time.
big poppa pump
San Antonio, TX
« Reply #11 on: October 16, 2015, 09:53:39 PM »
You can find Krud Kutter at Wally world. I used a 50:50 mix when I did my carbs, jets and other miscellaneous parts. For the really nasty bolts and parts that I kept for the last run, I used 100% KK, did a fantastic job.
VRCC#35870
VRCCDS#0266
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #12 on: October 17, 2015, 05:49:03 AM »
Did you use the gray label that say parts cleaner on it ? The only place I have found that one is Tractor Supply
« Reply #13 on: October 17, 2015, 06:42:10 AM »
OK, Tractor Supply is good. I can stop at WW on the way just in case since it's in the same direction. Wow....three carbs at once. Mine is nowhere near that big; one carb body and a few assorted smaller items. Maaaybe two if I leave out the small stuff. Thanks for the mix suggestions Big Poppa....and by the way, I'm loving that red/black more every time I see it.  cooldude
dragonslayer
palm bay fl.
« Reply #14 on: October 17, 2015, 07:15:10 AM »
when you use the Ultrasonic cleaner do you completely disassamble the carbs?
2k IS
98 Tour
2001 Stand
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #15 on: October 17, 2015, 07:58:38 AM »
I will
srteach
Twin Falls Idaho
« Reply #16 on: October 25, 2015, 02:51:07 PM »
I use an ultrasonic cleaner for vault time locks at work. Didn't think about other uses ... hmmmm....
Yes, you disassemble as far as you can to clean.
dancnman
Houston, Texas
« Reply #17 on: November 02, 2015, 08:40:50 AM »
What brand of Ultrasonic Cleaner do you have?
Reality is that thing which does not change simply because I choose to ignore it.
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #18 on: November 02, 2015, 09:55:00 AM »
Kendal
dancnman
Houston, Texas
« Reply #19 on: November 02, 2015, 10:12:39 AM »
Which one and are you happy with it.
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #20 on: November 02, 2015, 10:16:16 AM »
I bought the one that has 980 watts and yes very happy with it.
Grumpy
Tampa, Fl
« Reply #21 on: November 03, 2015, 05:25:34 PM »
I do about 6 to 7 sets of carbs a month, and I have noticed a change also. A lot of them have deposits that almost look like calcium buildup.  A white substance appearing  around o-rings etc. it is a pain to get off some times, I also use an ultrasonic cleaner with good results.
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #22 on: November 03, 2015, 05:49:43 PM »
Grumpy try the Krud kutter parts cleaner it will dissolve that stuff that we are seeing on the carbs from this new fuel. I have also notice a green deposit in the body and float bowls that carb cleaner won't clean but the Krud kutter will dissolve it
Grumpy
Tampa, Fl
« Reply #23 on: November 03, 2015, 06:15:08 PM »
I will give that a try, been using purple power, used to work great but does not seem to cut the calcium buildup.
« Last Edit: November 03, 2015, 06:43:49 PM by Grumpy » Logged
« Reply #24 on: November 03, 2015, 06:52:58 PM »
Damn Bill, you are supposed to be retired.  Grin
Pappy!
Central Florida - Eustis
« Reply #25 on: November 04, 2015, 06:01:23 AM »
Yeah, right!
Now he is getting into Antique Outboards as well as the bikes!
Grumpy
Tampa, Fl
« Reply #26 on: November 04, 2015, 08:21:44 AM »
Keeps me off the streets.  crazy2
