February 11, 2026, 04:01:35 AM *
Author Topic: speedometer, tach and odometer all stopped  (Read 2462 times)
abrock52
« on: October 15, 2015, 05:52:00 PM »
I have a 99 interstate and went for a ride when my tach ,speedometer and odometer stopped. I do not have any blown fuses. Odo shows on the screen and trip works. My lights all work . Made sure battery was charged and with key on engine off I still don't have odometer.  Help!
Grandpa Bigbuck
Paola, KS
« Reply #1 on: October 15, 2015, 06:59:53 PM »
Sounds like symptoms of bad alternator.
« Reply #2 on: October 15, 2015, 07:10:09 PM »
+1 check the output on the alternator.
Firefighter
Harlingen, Texas
« Reply #3 on: October 15, 2015, 07:12:42 PM »
The Honda manual says to remove the "Combination Meter" (gauge assy.) Check for 12 volts at the black/brown wire in the plug in harness. Should be 12 volts with the ing. switch on.
Check for continuity between the green/black wire terminal in the plug and ground. There should be continuity.
If no voltage or no continuity check for open circuit in the wire harness.
The plug in connector could have a bad connection.
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
Steel cowboy
Spring Hill, Fl.
« Reply #4 on: October 15, 2015, 07:30:36 PM »
The volt meter's red lead on the positive side of the battery and the black lead on the ground side. should tell you if the alternator or battery is bad.
If the read out is above 13.5 volts when the engine is running, Then alternator is charging.
2001 black interstate
2003 Jupiter Orange wing
« Reply #5 on: October 15, 2015, 08:08:02 PM »
True and his symptom has been had by many over the years and it lead to an alternator going bad.
« Reply #6 on: October 15, 2015, 08:50:51 PM »
Yep it was my first symptom. Wish it would have dawned on me what was going wrong.
« Reply #7 on: October 15, 2015, 09:17:02 PM »
It will run for a bit when all the dash read outs quit. Go on ahead and ask me HOW I know!  2funny  As already stated-first symptoms of an alternator takin a dump!  Lips Sealed RIDE SAFE.
abrock52
« Reply #8 on: October 16, 2015, 04:08:01 AM »
I have 13.88-14.2 volts  when I checked the alternator. With engine off and key on the odometer doesn't work
Steel cowboy
Spring Hill, Fl.
« Reply #9 on: October 16, 2015, 12:45:27 PM »
Just saying..You did check both fuse boxes. On my interstate there is another fuse box that houses 3 more fuses and a spare just to the right of the main fuse box.
abrock52
« Reply #10 on: October 16, 2015, 01:28:16 PM »
Yes fuses are good
abrock52
« Reply #11 on: October 16, 2015, 01:44:00 PM »
I have 11.5 volts at black and brown wire and continuity at one green and black wire.
Firefighter
Harlingen, Texas
« Reply #12 on: October 16, 2015, 05:55:28 PM »
did you find a green/black wire?
1978 Honda 750
Firefighter
Harlingen, Texas
« Reply #13 on: October 16, 2015, 06:09:56 PM »
Do you have a manual? I cannot see the diagram good enough, glasses and magnifying glass! Need to enlarge on a copier.
1978 Honda 750
Firefighter
Harlingen, Texas
« Reply #14 on: October 16, 2015, 06:23:40 PM »
looks like there is a green/black ground on the frame somewhere, I am looking to see if I can find where.
1978 Honda 750
dragonslayer
palm bay fl.
« Reply #15 on: October 17, 2015, 07:24:32 AM »
This has come upbefore and if you do a search for this problem you will find an article about a plug connection in front of the rear tire that corrodes/gets dirty.Clean it up and it might solve the problem.
2k IS
98 Tour
2001 Stand
Thunderbolt
Worthington Springs FL.
« Reply #16 on: October 19, 2015, 03:50:39 AM »
Here is a link to RP Brown's schematics.  MUCH easier to read than the manual or another online schematic.
http://www.rattlebars.com/valkfaq/schematics/
Highbinder
Bastian/Tazewell,VA.
« Reply #17 on: October 21, 2015, 06:57:01 AM »
Check your diode, that's the vertical looking fuse in your fuse box to the right of the reg. fuses....it isn't actually a fuse but looks like one....I had a similar problem, replace the diode and all was well....I was told this diode regulates the electrical system, if you have another bike just switch them or go to a dealer and get spare...hopes this helps...
