February 11, 2026, 04:01:49 AM *
Author Topic: Wiring for accessory light on my "new" Tourer  (Read 1076 times)
« on: October 22, 2015, 09:47:56 AM »
I have  a light bar and a pair of fog lights on the crash bars.
The previous owner/owners have created a birds nest of wiring and relays under the left side cover.
I want to replace the wiring and tidy the birds nest up.
What gauge wire do I need to use?
« Reply #1 on: October 22, 2015, 10:46:29 AM »
There's tables on the innernet to look at:
http://www.cerrowire.com/ampacity-charts
Lights and big horns and heated-gear leads and
air-pump leads draw the most amps of any
accessories that I have.
14 gauge is enough for 15 amps. None of the
things I listed above should require more than
that, unless you try to hook two sets of heated
gear to one lead. I guess you have a separate
circuit for each accessory.
Stay away from that 750 gauge wire  Wink
16 gauge should be OK too, but I think there's no
downside to 14 except that it costs more...
« Last Edit: October 22, 2015, 10:50:18 AM by hubcapsc » Logged
« Reply #2 on: October 22, 2015, 11:21:10 AM »
Thanks Mike,
I'll go with 14 gauge.
I'm going to run each accessory in a different color wire to make it easy to trace a fault in the future.
« Reply #3 on: October 22, 2015, 12:35:01 PM »
I'm going to run each accessory in a different color wire...
As I remember, that's where "costs more" bit me in the rear end...
After about five years my un-loomed heated gear wire rubbed
through and shorted out  - I redid everything with looms... can't
see the color when the wire is in a loom...  Wink
I don't know if this was smart or not, but I used unshrunk shinkwrap for my looms,
the only other stuff I could find was that awful "vacuum cleaner hose" stuff - the dog's
bollocks...
BonS
Blue Springs, MO
« Reply #4 on: October 22, 2015, 03:27:57 PM »
(I could suggest using the gauge that comes with the SmartSwitch!)
« Reply #5 on: October 22, 2015, 05:16:21 PM »
For under $20 you can get a labelmaker. I printout labels and wrap wires at terminals.
« Reply #6 on: October 22, 2015, 06:56:46 PM »
Yep I'll be doing that as well.
I have 2 sets of driving lights
Heated handlebar grips
Battery volt indicator
Extra rear lights
Kisan brake modulator
HID headlight
Dual accessory horns
That's all I remember right now.
Mtn Valk
North Ga.
« Reply #7 on: October 23, 2015, 05:37:27 AM »
I haven't heard anyone chime in regarding BonS new SmartSwitch. I believe this is something that could be very useful. Is there anyone that has tried this product and has a review to share? I'm interested!
J3
« Reply #8 on: October 23, 2015, 06:38:03 AM »
What's a Smart Switch?
BonS
Blue Springs, MO
« Reply #9 on: October 23, 2015, 07:04:55 AM »
I've had a "soft opening" for it as I want to keep up with orders. There are three versions: one for single headlights on Standard and Tourer, one for Interstates and one for fog and running lights. It's only been a week so no reviews yet. The SmartSwitch is a manufactured wiring harness that routes full voltage to your head and running lights while bypassing the high currents around your handlebar switches. It's plug-and-play and your handlebar switches work the same as they always do. Additional info is here http://thedigisync.com/. I'll be glad to answer any additional questions.
Oh, and it makes a huge difference on the Valkyries headlight brightness. Our headlights don't run anywhere near the wattage stated on the bulb due to the factory OEM harness wiring length, gauge, connectors, ignition switch and handlebar switches. I've seen anywhere from 25-40% increases. The quartz-halogen bulbs last longer too.
« Last Edit: October 23, 2015, 07:08:57 AM by BonS » Logged
« Reply #10 on: October 23, 2015, 07:52:43 AM »
I have an HID headlight. Does the switch work with that?
« Reply #11 on: October 23, 2015, 08:02:35 AM »
Here are a couple of good web pages for determining wire size:
http://www.gtsparkplugs.com/WireSizeCalc.html
http://www.powerstream.com/Wire_Size.htm
« Reply #12 on: October 23, 2015, 08:54:14 AM »
You assume that I have some basic knowledge of electricity. Eeeeek!
BonS
Blue Springs, MO
« Reply #13 on: October 23, 2015, 09:00:04 AM »
Yes it does. My headlight models come with H4 style plugs. The running/fog light come with universal connections. I haven't tested an HID for brightness differences as I have for quartz-halogen and LED but you'll definitely take the load off of your handlebar switches. I'll have to get my hands on an HID bulb to check it out.
big poppa pump
San Antonio, TX
« Reply #14 on: October 23, 2015, 09:20:57 AM »
HID kits usually comes with it's own set of relays since the ballast needs to be powered directly from the battery. The smart switch is not needed in this case.
However I did use this when I had a HID kit installed on my Valk. Even though a Xenon bulb consumes less power than a comparable Halogen bulb, the power draw from a typical 55W HID ballast at startup is quite a lot resulting in faster battery drain. HID bulbs usually take a few seconds to come to full power. Turning the bulb on/off when cranking kinda reduces the life of the HID bulb. With this relay, you can manually set how long it will take for your headlight to come on. I had mine set to 15 seconds.
http://www.wolstentech.com/products/timedelayrelay/tdr-s.php
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
Paladin528
« Reply #15 on: October 23, 2015, 10:38:47 AM »
my understanding is that the Interstate headlights are already routed through a relay to relieve the start button of the load of 2 headlinghts.  Would the smart switch not be redundant in this case?
BonS
Blue Springs, MO
« Reply #16 on: October 23, 2015, 11:05:28 AM »
my understanding is that the Interstate headlights are already routed through a relay to relieve the start button of the load of 2 headlights.  Would the smart switch not be redundant in this case?
The IS does have a relay that relieves the handlebar switches from the load. But that's all that's accomplished.  The OEM headlight voltage is still way below par because it routes through the ignition switch, connectors, and a long way through the OEM wiring harness which is under gauge. I picked up 36% high beam brightness (wattage) and 30.5% low beam brightness (wattage) on my Interstate.
BonS
Blue Springs, MO
« Reply #17 on: October 23, 2015, 11:07:36 AM »
The time delay relay makes sense for HID's and if HID's come with relays and suitable wiring that feeds directly off of the battery then there is no need for the Smart Switch.
Tailgate Tommy
Fort Collins, Colorado
« Reply #18 on: October 23, 2015, 12:09:25 PM »
I purchased, and just received in the mail, one each of the single, double, and fog light wiring harnesses. My winter project is to add them to both my IS and standard. I can say that they look awesome and very well made!
