May 02, 2026, 02:58:15 AM *
Author Topic: shift lever to short  (Read 3185 times)
dans2014
« on: October 26, 2015, 01:48:15 PM »
 Shocked Hey I have big feet and the stock shift lever doesn't come out to the side enough. Any suggestions?? And no, I'm not going to shave my feet!! ha ha .
Dan's 2014 Valkyrie
wayngo333
Ormond Beach , Fl
« Reply #1 on: October 26, 2015, 04:05:50 PM »
I have the same issue, really looking for a solution.
bscrive
Ottawa, Ontario
« Reply #2 on: October 26, 2015, 05:05:06 PM »
Get a heel-toe shifter.  Then you don't have to try to put your big foot in there.
wayngo333
Ormond Beach , Fl
« Reply #3 on: October 26, 2015, 05:09:44 PM »
Yep, found it. Pricey but man, nice set up.    http://www.kuryakyn.com/products/290/driver-floorboard-kit
blackvalk
PARK CITY, UTAH
« Reply #4 on: October 26, 2015, 07:25:17 PM »
The only issue with a heel/toe shifter is getting a big shoe or boot wedged between the front and rear pegs.
I have that set up and love it but my feet are small.
Bill
« Reply #5 on: October 27, 2015, 04:38:06 AM »
The shift lever is adjustable and does help somewhat in the problem. But on the other side you better have good flexibility in your ankle.
Pete
« Reply #6 on: October 27, 2015, 06:21:36 AM »
Cut the projection off then drill and tap for a bolt with nut that is long enough.
Cover the bolt with black hose cut to length.
bscrive
Ottawa, Ontario
« Reply #7 on: October 27, 2015, 10:04:40 AM »
I purchased just the heel-toe shifter.  I think it was $150 on eBay.  I used some mini floorboards that I had kicking around from my wife's old 750 Shadow.
http://www.ebay.com/itm/Kuryakyn-Heel-Toe-Shifter-For-Honda-Goldwing-GL1800-F6B-Valkyrie-4039-/291542972224?hash=item43e150b740:g:7BgAAOSwPcVV03RU&vxp=mtr
dans2014
« Reply #8 on: October 27, 2015, 04:03:04 PM »
I had a Suzuki 800 Volusia with the heel-toe shifter and it was also a problem with getting stuck and ankle flex so that wont work. It's not a horrible problem just not perfect
Dan's 2014 Valkyrie
