November 20, 2025, 01:46:00 AM
Drive Shaft to Pinion Cup Seal
Topic: Drive Shaft to Pinion Cup Seal (Read 1831 times)
Cyclejohn
Reidsville,N.C.
September 09, 2009, 03:47:47 AM »
Can the drive shaft to pinion cup seal (stopper ring) be re-used or does it need to be replaced every time you do drive line maintenance? Thanks in advance for the advice. JOHN
Daniel Meyer
The State of confusion.
Re: Drive Shaft to Pinion Cup Seal
September 09, 2009, 04:46:09 AM »
If it's in good condition it can be reused. If it gets worn it will tend to walk it's way out of position.
I don't change it often (I inspect/clean the pinion cup every 10,000 miles) but I keep one on hand just in case it's needed (cheap part).
CUAgain,
Daniel Meyer
Cyclejohn
Reidsville,N.C.
September 09, 2009, 02:24:00 PM »
Thanks Daniel, John
=> InZane XXV
