Atl-Jerry
« on: October 27, 2015, 09:44:00 PM » |
I have an IS that has sat for 3 years that I'm trying to get back on the road. If the carbs need to come off for cleaning, what should that cost? I was quoted $420 for this (1 hour per carb @ $70 per hour). Is this in line?
Thanx
Mr.BubblesVRCCDS0008
« Reply #1 on: October 28, 2015, 12:48:58 AM » |
That would be cheap does that include removing them from the bike or you pulling them and bringing them to the shop. I just pulled mine and they are on my work bench waiting for new slow jets. Not that hard to pull couple of hours to remove.
Mtn Valk
« Reply #2 on: October 28, 2015, 05:18:01 AM » |
About 3 years ago I was quoted $75/hr per carb, so yes that is probably on the low side. Keep in mind that is only an estimate as there is always the possibility of additional parts & labor depending on what they run into.
J3
signart
« Reply #3 on: October 28, 2015, 06:01:10 AM » |
If they know what they are doing, that's cheap. If they don't, anything you pay is too much.
grepper
« Reply #4 on: October 28, 2015, 06:34:36 AM » |
I got all the service records when I got my Valk. It was over $500 for a shop to clean the tank, pull and clean the cabs.
New to Valkyries and Big Bikes in general. Other Bikes: 1978 xs650 Standard, 1979 XS650 Bobber, 1975 CB750 K5 (Wife's Bike), 1979 & 1981 CB750K (basket Cases), plus a Whahoo Scooter (Cheap Chinese thing I got for free).
« Reply #5 on: October 28, 2015, 08:08:37 AM » |
If you are some what mechanically inclined while involved it IS doable. I know one of the best people here for carb work BUT he lives in Tulsa Ok. He also has a new ultra sonic cleaner that is working gang busters. MAYBE pull carbs and send them to him for the internals. P M him for yuks and giggles. Oh-he goes by Atticrat on this here forum. On the plus side-when he's done with the cabs-they ARE right. Ask my brother-da prez-he has a set redone by Atticrat. And THEN he digisynced them-and my I/S was digisynced-well digisync is now plug for BonS-again a board ember and board sponsor. This post should give you a few options to mull over!  Believe Atticrats thing about airwings has his Phone number included. RIDE SAFE.
« Last Edit: October 28, 2015, 12:10:44 PM by old2soon »
stude31
« Reply #6 on: October 28, 2015, 11:46:53 AM » |
$420.00 Holy smokes!! I need to raise my price.
I know Bob in Tulsa and he does an awesome job. I pull them off the bike, take them apart, so each one, install new carb kits, put carbs back together, install back in bike, and synch carbs. I hate asking for money but having five kids my time is worth something more than I thought before the kids. I know that between soaking the carbs for 3 hrs it takes 6 hrs in the bath and about an hour per carb sounds about right.
Stude31
quirkyguy001
finally found a way to hold the dragon back
Tulsa, Ok
« Reply #7 on: October 28, 2015, 02:25:51 PM » |
I had mine done by Attic Rat. He takes a lot more time then an hour per carb. You might want to check with him, he is higher, but really does a great job. I won't say what he does, but e mail him and he will tell you. He is a member
Used to buy new bike every two years. Can't find anything to upgrade to. Harley rider for 40 years. Nough said
« Reply #8 on: October 28, 2015, 05:04:09 PM » |
Does the bike start and run? Fresh gas?
If so, try the cheaper way first. Carb cleaner in fresh gas, high strength. Ask more if it runs. I would rather spend $10 on carb cleaner that will/might get it running after a season of riding, instead of what should cost more than $500 to do, more if you don't remove the carbs yourself.
Atl-Jerry
« Reply #9 on: October 28, 2015, 08:53:08 PM » |
Thanx for the responses, much appreciated. I haven't got the tank back yet so today I pulled the plugs and sprayed in some WD40 and turned it over several times to ensure it wasn't locked. I put in the new battery and connected a temporary fuel tank and it fired up and ran after about 10 seconds on the starter. After about 15 seconds it smoothed out and ran on all cylinders. I didn't expect that.
Pappy!
« Reply #10 on: October 29, 2015, 07:11:53 AM » |
Was that price including parts? No mention of that.
Atl-Jerry
« Reply #11 on: October 29, 2015, 08:27:48 AM » |
No, labor only, parts extra.
valkyriemc
NE Florida
« Reply #12 on: November 01, 2015, 02:23:26 PM » |
When I did my carbs a couple of years ago I used a youtube video that really helped. That and patience. G/L https://www.youtube.com/watch?v=eDLTpQCTBsc
« Last Edit: November 01, 2015, 02:30:17 PM by valkyriemc »
Veteran USN '70-'76
