February 11, 2026, 05:47:39 AM
some help for putting the boot on
Topic: some help for putting the boot on (Read 1010 times)
saddlesore
October 28, 2015, 11:24:56 AM »
Not wanting to use a screw driver on the boot I thought of using these bicycle tire spoons. It's not a cure all but it got the job done in ten minuets and no holes in the boot...... Maybe just dumb luck?
DARE TO BE DIFFERENT
jdp
Re: some help for putting the boot on
October 28, 2015, 04:33:37 PM »
Are you talking about a boot that you wear?
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
October 28, 2015, 04:40:59 PM »
Quote from: jdp on October 28, 2015, 04:33:37 PM
I'd say he means the boot over the u joint
saddlesore
October 28, 2015, 05:42:38 PM »
You're right, I meant the PITA boot over the u-joint.
I should have made that clear. I wouldn't want to be "misunderstood".
Williamsburg, KY
October 29, 2015, 01:54:07 AM »
Quote from: saddlesore on October 28, 2015, 05:42:38 PM
BobB
October 29, 2015, 02:27:21 PM »
I knew exactly what Saddlesore was talking about, there is only one PITA Boot on our Ladies. But you have to experience the removal and reassembly of that boot to know that. I may have those bicycle tools somewhere in my workshop...
Last Edit: October 29, 2015, 02:29:42 PM by BobB
da prez
Wilmot Wi
Reply #6 on:
October 29, 2015, 07:57:56 PM »
Years ago when disc brakes first came out on cars , there was a boot expander used to install without tearing. Any old mechanics have one to try. When I get done with my two cents worth (before taxes) I will look and see if flea bay or amazon has one.
I just went on E-bay. The tool is Herbrand 608 disc brake boot expander pliers. $22.00
da prez
Last Edit: October 29, 2015, 08:23:45 PM by da prez
