November 26, 2025, 03:17:03 PM
Took my alt to have serviced today.
Topic: Took my alt to have serviced today. (Read 965 times)
October 29, 2015, 02:22:53 PM »
Had it off at 50k for a 'professional' to look at it. Back then he said the brushes should last another 50k. Im at almost 100k so since riding season is over might as well take it off. Told him to replace everything that needs it before the next 50k. He asked if it still charges and I said yes. He said good cause some parts are getting hard to find. Should be done tomorrow he says.
Prob do the starter this spring. He did it at 5-k also and replaced a bearing I believe. Gosh I hate taking the starter out.
Re: Took my alt to have serviced today.
October 29, 2015, 06:05:25 PM »
what parts are getting hard to find?
October 30, 2015, 02:04:18 PM »
He replaced 2 bearings and the brushes. All for $89. Brushes were shot he said. I asked if its good to go for another 50k and he said prob longer.
Last Edit: October 30, 2015, 02:09:16 PM by fudgie
October 30, 2015, 02:08:15 PM »
Quote from: CA on October 29, 2015, 06:05:25 PM
Hes having trouble finding some bearings. He had one left. Its a standard outside diameter but the inside diameter is large and hard to find. He said Honda wont release parts so he cant get them from them.
Hes worked on lot of wing alts as he is a wing rider.
October 30, 2015, 05:21:59 PM »
"Front seal: CR8845
Front bearing: 6022DU
Rear bearing: 6000DU"
"I have not done these repairs but have "borrowed" this information from Goldwingfacts.com"
http://www.valkyrieforum.com/bbs/index.php/topic,73080.0.html
Blackduck
West Australia
October 31, 2015, 08:49:49 PM »
Think the front bearing maybe 60/22DU (22x44x12) not 6022DU as it is 110x170x28
6000DU comes up as 10x26x8.
Bearings with the forward slash in the number are usually designated as motorcycle bearings.
=> InZane XXV
