February 11, 2026, 05:47:34 AM *
Author Topic: Fuse--what capacity?  (Read 712 times)
Fazer
« on: November 03, 2015, 10:05:01 AM »
Adding the Dan-mark shut off.  What size fuse should I use?
Nothing in moderation...
« Reply #1 on: November 03, 2015, 09:02:48 PM »
It doesn't draw much power.  5a is good.
« Reply #2 on: November 04, 2015, 03:19:18 AM »
There are acc. wires under the right side cover which I think come from the 5 amp fuse in the panel.
Fazer
« Reply #3 on: November 04, 2015, 07:38:28 AM »
Thanks Mark and Patrick.  I am using the accessory circuit to power a relay that in turn powers a fuse panel which I use for my driving lights, horn and amp.  I did not think the dan-marc would take a large fuse, but always appreciate the help on the board.
greg
« Reply #4 on: November 04, 2015, 08:22:59 AM »
greg
I do the same on powering an auxiliary fuse block with the accessory wire. As Mark suggested , I'm using a 5amp fuse on the Dan Marc circuit.
My rides:
