February 11, 2026, 05:46:20 AM
OEM Filter?
Topic: OEM Filter? (Read 974 times)
RIX97
OEM Filter?
November 03, 2015, 02:20:52 PM »
I have a 1997 Valkyrie Tourer and when I purchased it, the previous owner gave me a new unused filter still in the plastic wrap. Today when changing the filter I noticed the new one was a different number but still fit. Physically, it appears to be a little larger as my oil filter wrench was very tight on the new one and the chrome oil filter cover I took off the old one will not go back on the new one. I could care less about that but was wondering if there is much difference in the filters other than the size. The old one is a Honda OEM 6C24 filter and the new one is a Honda OEM 6V21.
Thanks in advance.
BTW, I tried searching and was confused than when I started.
Rick
Re: OEM Filter?
November 03, 2015, 02:43:30 PM »
the honda filter is used on most of their bikes. when the GL1800 came out they made the filter slightly smaller.
just google the #s and see what comes up.
Re: OEM Filter?
November 03, 2015, 05:32:52 PM »
No problem with it. When I had my VTX the filter was a tad smaller but eventually used the same as on my Valk kust to keep from having two different ones on my shelf.
RIX97
Re: OEM Filter?
November 04, 2015, 06:31:23 AM »
Thanks guys, appreciate the advice.
Re: OEM Filter?
November 04, 2015, 07:09:01 AM »
The part number for the OEM filter is 15410-MFJ-D01. I don't think the numbers you mention are part or model numbers, but might be manufacturing batch codes. See the photos below all have the same part number, but different batch codes.
