February 11, 2026, 05:47:42 AM
Big hands and clutch bleeding
Topic: Big hands and clutch bleeding (Read 758 times)
November 06, 2015, 01:56:34 AM »
I want to replace the OEM nipple with a speed bleeder.
Problem is I can't do a quick change cause of my big mitts.
If I drain the fluid out and then replace the nipple will I have a problem then filling the system with brake fluid successfully and no air in it?
Re: Big hands and clutch bleeding
November 06, 2015, 04:28:20 AM »
You'll probably have a problem getting fluid to start flowing, but after
that you should be successful. I have speed bleeders, but my priming
trick involves a quick change...
November 06, 2015, 06:30:44 AM »
I don't think I would do a thing. Just wrap a rag around the line, remove the old bleeder and install the new.
But, then I do things the old fashioned way. There is room for me to get my hands in there to manually bleed the clutch. So I don't know what else to say, sorry.
Roidfingers
Tuscaloosa, Alabama
November 06, 2015, 03:18:03 PM »
Not sure what the problem is. I changed to speed bleeders and got it no hurry when I got one out then the other in. Very little fluid loss. Just make sure you leave the resevoir covers on when doing so. It creates a vacuum where the fluid will not flow fast.
November 06, 2015, 05:11:50 PM »
Quote from: Roidfingers on November 06, 2015, 03:18:03 PM
Ah ha. That could help.
Roidfingers
Tuscaloosa, Alabama
November 06, 2015, 05:15:58 PM »
Hope that helps britman. Let us know.
Reply #6 on:
November 06, 2015, 05:20:18 PM »
Quote from: Roidfingers on November 06, 2015, 05:15:58 PM
Next time I'm due for a clutch flush I'll try to remember that. Thanks.
I'll make a note on my maintenance spread sheet.
