February 11, 2026, 07:41:22 AM *
Author Topic: 97 valkyrie clutch issues  (Read 930 times)
mmagg2
« on: November 09, 2015, 08:19:11 AM »
I can't get my baby to go into neutral unless I turn engine off, and then it is hard sometimes tickedoff please help
« Reply #1 on: November 09, 2015, 09:02:15 AM »
You need to pull in the clutch lever, its the one on the left.
Sorry, couldn't resist.
How does the lever feel ? I'd recommend starting there. Is there air in the system ? Is the lever and bushing in good condition ?  I haven't heard of much master/slave problems.
If they are all good, then maybe the clutch itself has a problem.
mmagg2
« Reply #2 on: November 09, 2015, 09:07:15 AM »
That was a good one  cooldude I have taken slave cylinder off and cleaned it out and put it back on changed fluid in master cylinder and bled it got good tight clutch action.
« Reply #3 on: November 09, 2015, 11:03:28 AM »
Good. Glad it was easy. I like easy. How much crud [ technical term] came out of the cylinder ?
mmagg2
« Reply #4 on: November 09, 2015, 06:25:26 PM »
A lot but still can't go to neutral without killing engine. Any ideas ?
Steel cowboy
Spring Hill, Fl.
« Reply #5 on: November 10, 2015, 02:52:35 AM »
It might have something to do with the neutral switch not lined up properly. I have to fiddle with my lever to get the light on even though it's in neutral.
2001 black interstate
2003 Jupiter Orange wing
« Reply #6 on: November 10, 2015, 07:53:31 AM »
I guess maybe more explanation might help. For instance: "good tight clutch action". What does this mean?
And again, If you're killing the engine when shifting to neutral, does this mean all the time, like when riding
and when you're stopped. Does gear clashing occur?
I think with what's been posted so far, you're problem is the clutch has not been completely bled of air.
Old Geezer Richard
San Antonio , Tx
« Reply #7 on: November 10, 2015, 09:45:22 AM »
Hey mmagg , read my post on Possible Clutch Problem and see if you have the same or similar symptoms ....  Thanks the Geezer   crazy2
