November 26, 2025, 07:56:47 PM *
Author Topic: Cyc popping  (Read 1338 times)
Jym777
Silver Springs Fl
« on: November 18, 2015, 04:19:37 PM »
Hay guys, would it be in one of my carbs that cause a popping sound out of one of the left cylinder at between 1000-1500 rpm in first or second gear? Really bugging me!! Any and all help much appreciated, Thanks, Jym..
« Reply #1 on: November 19, 2015, 07:07:26 AM »
Sounds like the classic case of varnished low jets. Try several tank fulls with heavy doses of fuel cleaner.
Jym777
Silver Springs Fl
« Reply #2 on: November 19, 2015, 10:13:51 AM »
Thanks Pat, I'll try that first, easier than pulling carbs apart!!
« Reply #3 on: November 19, 2015, 11:59:30 AM »
Jym use Chemtool B12.  Use a can in a full tank.
My rides:
« Reply #4 on: November 19, 2015, 06:03:23 PM »
And ride it at very low rpms .
NDFRC
Orange Park FL
« Reply #5 on: November 20, 2015, 03:30:25 AM »
Understand low RPMs and cleaning out slow jets, but riding a Valk at very low RPMs is definitely an oxymoron!
« Reply #6 on: November 22, 2015, 09:58:39 AM »
LOL !  Thats just completely against basic human nature isn't it !
But, keeping the engine speed from idle to about 2500 keeps most of the fuel moving thru the low circuit.
Flat6Valk
Blacklick, Ohio
« Reply #7 on: November 23, 2015, 12:05:02 PM »
Check you vacuum tube too.  Even a tiny bit loose or tiny crack will cause havoc.  Especially on warm days.
And check the screws holding the rubber tubes to the manifolds.
Greg
Flat6Valk
Oldnick
Western Australia
« Reply #8 on: November 23, 2015, 05:42:29 PM »
I had a lot of popping and crackling at 1000-3000- rpm no load because of a loose tube on the rear left cyclinder that is the vacuum line to the tank.  Worth checking that at both ends as well. IT can also cause fuel feed trouble
Nick
May God save us from believers!
IamGCW
727 hood
« Reply #9 on: November 24, 2015, 05:58:32 AM »
+1 on the intake clamps.
Could also be the start of a fuel valve leak, vacuum port cap leak, or intake O ring leak.
Gil
Gil
Jym777
Silver Springs Fl
« Reply #10 on: November 25, 2015, 03:22:43 PM »
Thanks so much guys, good info! Much appreciated!!
Oldnick
Western Australia
« Reply #11 on: November 25, 2015, 10:03:06 PM »
Hope I am not condescending, but start simple, with the easiest stuff to check. Many are the times I wish I had listened to that.
IME, having a good look, at the plumbing under the tank generally, is not a bad idea. A lot of mine had perished at the ends, probably because of heat and vibration....and before anyone mentions the "nickel test"  Roll Eyes, there is road vibration as well Smiley
Nick
Nick
Pappy!
Central Florida - Eustis
« Reply #12 on: November 29, 2015, 07:36:36 AM »
Also try a good old carb sync.
Jym777
Silver Springs Fl
« Reply #13 on: December 01, 2015, 04:49:25 PM »
Cyc popping issue resolved! Thanks to all of you guys!! It was the vacuum line, I followed it from the left rear cyc and there it was unhook and just laying there, took a few minutes to figure where it went, hooked it up and no more popping! Thanks again you guys, much appreciated, Jym...
Steel cowboy
Spring Hill, Fl.
« Reply #14 on: December 01, 2015, 05:10:22 PM »
Left rear manifold that's number 6 carb.feeds vacuum to the petcock. If your bike ran with the vacuum line disconnect I would check it. Fuel should not be passing thru the stock petcock with out vacuum.
2001 black interstate
2003 Jupiter Orange wing
