February 14, 2026, 06:52:19 AM *
Author Topic: Shock Bushings  (Read 5474 times)
PAVALKER
Pittsburgh, Pa
« on: September 12, 2009, 08:16:21 AM »
While trying to isolate an issue on my bike I checked the shock bushings that I had previously replaced with stock shock bushings last year and noticed they were badly worn, not worn thru but worn and egg shaped.  I reworked the front end of my bike and am starting to look at the rear end of the bike and this was the first step (of many).  On the VTX message boards they addressed some new shock bushings for the VTX 1800F, that were harder neoprene or something (and look greenish not like the black rubber).  Well I got a set of these for the upper shocks on my VTX but there were still good so I installed them on the Valkyrie since they are the same size and probably the same shock.   They are much firmer and harder than stock shock bushings.  I have heard of others using nylon bushings from McMaster-Carr, but they don't have the taper like our shocks.  In any event I wanted to share the part number with you in the event you would like to try em out as well.   Part nr 52489-HNO-671 , a much better bushing (even cheaper than) that the stock black bushing.  My local dealer price matched DLP prices too....  a pair for under 5 bucks  cooldude
John
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #1 on: September 12, 2009, 01:15:14 PM »
Already got the stock ones for my rebuild of the final, but will keep these in mind for the future.  cooldude Thanks, Dave
« Reply #2 on: September 12, 2009, 05:52:19 PM »
www.rattlebars.com   see shock bushings  designed and sold by one of our board members
John U.
Southern Delaware
« Reply #3 on: September 12, 2009, 06:01:59 PM »
This link gets you to Gary's bushings. They have worked well for me, well worth the money.
No affilliation, just a satified customer.
PAVALKER
Pittsburgh, Pa
« Reply #4 on: September 12, 2009, 07:05:22 PM »
I have a set of Gary's bushings on my VTX and they are showing some wear after a few years now.  The newer design ones I got from Honda appear to be made from the same material as  Gary's.  They are somewhat less expensive as well......
John
upjeeper
« Reply #5 on: April 10, 2010, 11:13:55 AM »
I received in a couple of pair of bushings from Gary today. He was back ordered on material and I was ancy to get them in. After a few email messages he was kind enough to make getting mine out a priority.
Seems like a good guy and the installation was extremely easy (much easier then the removal of the old ones).
BradValk48237
Oak Park, MI
« Reply #6 on: April 10, 2010, 08:06:15 PM »
+1 on the VTX bushings...... price was right, $10 for upper and lowers..... $2.50 each.
Did them bout a month ago...... Will have to see how they last.
B
« Reply #7 on: April 10, 2010, 09:44:03 PM »
These harder VTX bushings: Who makes them and where do you buy them. The part number: is that a Honda number or some other company's?
PAVALKER
Pittsburgh, Pa
« Reply #8 on: April 11, 2010, 08:55:37 AM »
That is a Honda #....  go to your local dealer or DLP/HDL....
John
N0tac0p
« Reply #9 on: April 13, 2010, 05:55:17 AM »
has anyone heard from Puror letely?
N0tac0p
« Reply #10 on: April 13, 2010, 08:17:20 AM »
has anyone looked into replacing the top bushings on the valk shocks with the VTX bearings called out onthe top of the shocks?
Joe Hummer
Arnold, MO
« Reply #11 on: April 13, 2010, 09:09:35 AM »
I would say you would need the VTX Top Mount in order to do that.  You might be able to use the VTX shocks (if the length was right) but I am not sure I would do that on an I/S.  I also don't know if the Valk upper post would accept the bearing or not.  But it looks like the upper shock mounts screw into the frame on both bikes, so I don't know why you couldn't swap them over...as long as the shocks were the right length.
Joe
1999 Valkyrie Interstate
StrikingViking
My kind of 3D High Def
Abbotsford, BC
« Reply #12 on: July 26, 2017, 08:34:31 AM »
Thanks for this info!  I ran the part number and came up with a bunch of sites selling it.  One of the sites showed on a micro fiche that the top and bottom bushings have the same part number.  I'm upgrading the rear shocks on my '98 Tourer with a used set off an Interstate, so for the price I figured I'd replace the bushings all around.  Ordered 4 for $2.43 each from Partzilla.
VRCC #36924
~ '98 Burgundy/Cream Tourer
~ '98 Burgundy/Cream Standard (sold)
~ '97 Green/Cream Tourer (Bought new... sold)
« Reply #13 on: July 26, 2017, 08:26:10 PM »
I thought Gary's was our guy here in WA States, who passed back in 2012? or there abouts. I have a set of his which I just had put onto my IS, along with the rear dampeners.
I think someone else either had left over stock or the pattern for them, and was selling them still.
Maybe a link?
markdam
« Reply #14 on: May 05, 2018, 02:05:38 PM »
is there a difference between upper and lower part numbers?
CleoBen
2000 Interstate
Lewisburg. Ohio
« Reply #15 on: May 06, 2018, 06:10:59 AM »
Same part numbers for top and bottom as shown on Partzilla.  I just ordered a set of 4, as mine are looking worn.
CB
