February 11, 2026, 09:56:04 AM *
Author Topic: rear noise service  (Read 1227 times)
franco6
Houston, TX
« on: December 21, 2015, 01:30:14 PM »
Been tearing it down to check a clicking noise when at slow speed almost in time with the wheel spin .took the u-joint out ,no play anywhere, but the output shaft splines have a slant(slight).
the wheel bearings are relatively new (double) and spin well. the noise could be brake related but only happens when bike is hot. Could the alternator be loose?
Yes, pictures would be useful. Forthcoming.
Enjoy the ride!
Michvalk
Remus, Mi
« Reply #1 on: December 21, 2015, 04:49:19 PM »
Check and make sure the black plastic ring on the diff is setting in the proper location. That would be the one that is inbetween the rim and the diff. That thing can click if it is rubbing on the rim cooldude
« Reply #2 on: December 21, 2015, 05:48:29 PM »
I don't suspect the u-joint from what little you've mentioned, noise would be more and get worse.
But how did you check it? You are suppose to place one end in a vise, and force the other end. I'm sure I'm missing a little info on how-to, but you can look for that (or someone will reply) if you need it.
franco6
Houston, TX
« Reply #3 on: December 29, 2015, 07:53:14 AM »
After more cleaning , the splines on the joint and all others are fine, it s already back in with new grease.looking at the wheel now, rubber dampers specially. cooldude
Enjoy the ride!
indybobm
Franklin, Indiana VRCC # 5258
« Reply #4 on: December 29, 2015, 10:33:48 AM »
Probably not the u-joint. The click would not be one with every wheel rotation. It would be be more like 3 per rotation. For peace of mind, it never hurts to change the wheel dampers while you have it apart. Take a look at the brake pads to see if there is any unusual wear on them.
So many roads, so little time
VRCC # 5258
SteveBC777
2000 tourer red/black {minus screen}
Pattaya Thailand
« Reply #5 on: December 29, 2015, 05:28:42 PM »
It's also very easy to overlook the most obvious things, as we often tend to think the worst.
Check your back tyre for any stone or some other thing stuck in the tread surface. I once picked up a crown cap which made a hell of a 'click' when on the move.......
Steve.
Spannerman to some of the nicest chaps you could ever wished to of met .
franco6
Houston, TX
« Reply #6 on: December 30, 2015, 09:54:41 AM »
So tryed to turn the bearings again ,this time they were hard to turn. will not turn with fingers but will with a rubber handle(no rumble). also noticed discoloration on the left side of axle shaft as heat marks so methinks of going back to oem configuration and scrapping the double row bearing.
I have a spare axle. cooldude
Can t post picts as I ve lost my vrcc# and can t seem to retrace tickedoff
Enjoy the ride!
indybobm
« Reply #7 on: December 31, 2015, 06:33:55 AM »
If your first name is Fred and you live in Houston, your VRCC number might be 30722.
« Last Edit: December 31, 2015, 06:50:43 AM by indybobm » Logged
VRCC # 5258
« Reply #8 on: December 31, 2015, 11:30:34 AM »
With the wheel removed from the bike, the internal spacer easily interferes with manual rotation of the bearings
