February 11, 2026, 09:56:28 AM *
Author Topic: Red Fluid on rim on front of 98 Tourer?  (Read 1161 times)
Squirtstoy21
« on: December 31, 2015, 04:10:01 PM »
Good Evening,
I am new to the Valkyrie family. I just purchased a 1998 two weeks ago. I now have gone out and looked at the bike and it has red fluid at the bottom of the rim on the front of my Valk. What is this from? Brake fluid? I couldn't find anything on the forum about colors of fluids. Any suggestions are appreciated.
Happy New Year to All,
Craig
Summerfield, NC
« Reply #1 on: December 31, 2015, 04:19:56 PM »
Sometimes front forks are rebuilt with ATF as it has similar properties of fork fluid. Check your fork seals for leaking. Clean it off and see if it returns.
big poppa pump
San Antonio, TX
« Reply #2 on: December 31, 2015, 05:54:03 PM »
Your front fork(s) is leaking. Search the forums for multiple topics about fixing the leak using a 35mm film.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
Ken Tarver
North Mississippi
« Reply #3 on: December 31, 2015, 06:34:37 PM »
Yup, fork oil
Ken
« Reply #4 on: December 31, 2015, 06:48:11 PM »
If it's been ridden, and assuming it's fork oil, there should be a fine spray on the timing cover, and a trail down the forks (and you want to be sure your brake pads are not oiled).  It will be thin and may not look red on the timing cover, wipe it with a white cloth and see if it looks red.
Then get a Seal Mate (OK) or Seal Doctor (much easier to use).
http://www.amazon.com/Motion-Pro-Seal-Mate-Cleaner/dp/B0039LDF4A
https://www.youtube.com/watch?v=8wlzfoVroSY
http://www.riskracing.com/pages/Seal_Doctor_Page.html
https://www.youtube.com/watch?v=W3Re9wpdNFg
Squirtstoy21
« Reply #5 on: January 01, 2016, 11:51:23 AM »
Jess
Thank you Sir. I will order one today.
I appreciate your help.
Craig
