February 11, 2026, 09:57:42 AM *
Author Topic: Austone taxi tire report  (Read 1180 times)
« on: January 16, 2016, 01:07:41 PM »
I put a ATT on my two up bike 17k miles ago.
When new, the middle grove mic'd out at .31 " or  7.98 mm.
Today, it mic'd out at .179" or 4.55 mm.
Still got more than half the tread left.
Mostly two up at 32-36 psi depending which gauge you want to believe.
Ken Tarver
North Mississippi
« Reply #1 on: January 16, 2016, 01:52:53 PM »
good milage Hook
« Reply #2 on: January 16, 2016, 02:02:42 PM »
What's the typical groove depth on a M/C tire?
Anyone?
« Reply #3 on: January 16, 2016, 03:08:50 PM »
rear cruiser tires most are 9/32,  E-3 is 10/32
hukmut
Stone County, Mississippi
« Reply #4 on: January 16, 2016, 05:07:29 PM »
32-36 psi?  Shocked
Am I mistaken that most folks run that tire at 42 psi?
 I run mine at 42.
Got about 5500 miles with no problems.
Ride safe.
« Reply #5 on: January 16, 2016, 05:42:25 PM »
32-36 psi?  Shocked
 I run mine at 42.
Ride safe.
I know the general opinion is to run around 42, but one reason I wanted to run a C/T was so I could get the longevity mileage at lower psi.
I've run it for 17K at 32-36 without issue.  Works for me.
Honda calls for 33-36 in the manual (on M/C tires) and the tire calls for 55 psi max, at max load of 1653 lbs.  The bike w riders & gear goes around 1200 lbs on two wheels.
Some riders have reported a wobble at high speeds at the lower psi, but I've not noticed any.
NewValker
VRCC# 36356
Oxford, MA
« Reply #6 on: January 16, 2016, 06:37:55 PM »
Last fall I bumped mine up to 42 from 39 and it felt awful.
Wouldn't think 3 lbs would make that much of a difference.
Going back in the spring.
Craig
Turns out not what or where,
h13man
Indiana NW Central Flatlands
« Reply #7 on: January 16, 2016, 08:30:34 PM »
My Pirelli 66's and the Exedra rear tires depth mic'ed .310/7.9mm deep new.
« Last Edit: January 19, 2016, 05:04:45 PM by h13man » Logged
« Reply #8 on: January 17, 2016, 05:43:07 AM »
Hey Bill, that tire is looking pretty good.  cooldude I've never seen a bad report about the ATT. I've been running dark side for quite a while but have been hesitant about them because of the height. Have you had any problems with bottoming on the fender ?
PAVALKER
Pittsburgh, Pa
« Reply #9 on: January 17, 2016, 05:45:22 AM »
Been quite pleased with mine all this past year.
John
« Reply #10 on: January 17, 2016, 05:58:46 AM »
Morning Rob,
When I put that tire on, I bought a set of used progressive shocks (either 11.5 or 12", can't remember which) to lower the bike from the high tire.
 Any ways, when 2 up, the tire would rub, I believe, on the wire cage.
I re-installed the OEM shocks and the rub went away.
I've gotten use to the extra height.  Never bothered me when riding and I have a 32" inseam, so my feet set flat.  It was the extra height when on the stand that was the only concern.
I've got m/c tires on my other rides and I really like the ATT.  Can't beat the mileage it's giving me.
Just wish it came with a lower profile.
