March 15, 2026, 03:21:14 AM *
Author Topic: New Valkyrie With Some Add Ons  (Read 3406 times)
Andy816
« on: January 18, 2016, 10:14:24 AM »
Hello fellow Valkyrie riders!
I bought my beauty about a month ago and its one sweet bike. I figured I'd post what I do to my bike for everyone's benefit, since I've had trouble finding specifics on adding stuff with good pictures.
The bike came with the OEM tall windscreen on it. This helped tremendously when I rode it down from Indiana to Florida over the Christmas break. But I definitely found the windscreen cause buffet which beat my head around and gave me a headache. I'm looking to add the OEM wind deflectors in hopes that it will relieve the buffet. In the mean time, I removed the Windscreen. I found that at 80+ mph without the windscreen, I can deal with the wind pushing me back, but I get uncomfortable after about 30 minutes.
https://drive.google.com/file/d/0BxtEb1TA0O5lMDgyYU1uNVdwc28/view?usp=sharing
https://drive.google.com/file/d/0BxtEb1TA0O5lQnA0YzJtNmY4OFE/view?usp=sharing
I found a nice "Waterproof" Jack and USB that mounted to the handle bar. It comes with an ON/OFF switch for the USB ports, but the jack is continuously powered. The USB has enough power to charge my phone while its navigating, so I can use the phone without worrying about battery life. I cut the wiring and heat shrunk it to cover the red wire. That way it didn't standout on the otherwise clean handlebars. I routed the wiring behind the headlight and fed it underneath the fuel tank without having to remove any parts, which was super nice. I wired it directly to the battery.
https://drive.google.com/file/d/0BxtEb1TA0O5ldGVKSXVad2NIREU/view?usp=sharing
https://drive.google.com/file/d/0BxtEb1TA0O5lVTRsOFFJNTlfOW8/view?usp=sharing
https://drive.google.com/file/d/0BxtEb1TA0O5lM0lqeVJTNmZjX1k/view?usp=sharing
https://drive.google.com/file/d/0BxtEb1TA0O5lLUNxUGxnOGNhLWc/view?usp=sharing
The USB cord goes right to the phone mount, and is springy so it doesn't get in the way. The phone mount keeps the phone about 3 inches above the tank, and is masked from the wind by the speedo, making it very stable and minimizing risk of the phone flying off the bike!
https://drive.google.com/file/d/0BxtEb1TA0O5laEZtdXZhLS1hYTQ/view?usp=sharing
While I'm waiting for the Corbin Saddlebags and Seat, I put on a Cortech tail bag I had lying around, since I hate wearing a backpack! Here's some pics of how its mounted and the space inside.
https://drive.google.com/file/d/0BxtEb1TA0O5lcHdlYUVaYVBxdVE/view?usp=sharing
Front Strap
https://drive.google.com/file/d/0BxtEb1TA0O5lSTdoTkZQOUlOUk0/view?usp=sharing
Rear Strap
https://drive.google.com/file/d/0BxtEb1TA0O5lUWVlR0xfVDVmUFU/view?usp=sharing
Inside
https://drive.google.com/file/d/0BxtEb1TA0O5lMjY2UmFyZm9vbFk/view?usp=sharing
I plan on documenting the install on the following in the coming months:
Ricvo Aero Pegs
Corbin Touring Seat with 2 backrests
Corbin Fleetliner Saddle bags
OEM Wind deflectors
Brakeaway Throttle lock
Fog lights
Centerstand and exhaust cover
I'll post what I think of each as I use it too.
I hope this adds to the forum for others to reference. Let me know if I should add anymore details. This bike is my transition from a sportbike, and hot damn is it comfy!
-Andy
« Last Edit: January 18, 2016, 10:23:51 AM by Andy816 » Logged
bscrive
Ottawa, Ontario
« Reply #1 on: January 18, 2016, 11:03:12 AM »
Hey Andy,
You will enjoy that bike like none other.  I have done a bunch of mods as well to make it mine. That the most fun part about a bike.  cooldude
One thing with the USB jack hooked directly to the battery.  It will draw power constantly, so if you don't ride the bike for a while it can drain the battery.  Don't ask me how I know  Wink.  There is a connector under the seat for what you need. It is attached to the plastic wall in the box under the seat.  Take off the seat, and connect the USB to that.  It is switched, so you won't be draining the battery when the key is off.
Brian
Andy816
« Reply #2 on: January 18, 2016, 11:26:04 AM »
thats what I'm talkin about, thanks for the heads up. I'll see if I can figure that out later in the week. If I can't find it I may ask you to take a pic of the exact spot if you can!
-Andy
FormerVTXRider
« Reply #3 on: January 18, 2016, 06:58:44 PM »
Front Strap
Rear Strap
Inside
Ricvo Aero Pegs
OEM Wind deflectors
Fog lights
-Andy
Andy re "I found a nice "Waterproof" Jack and USB that mounted to the handle bar. "  Can you post a link of where you found it?  I like the clean look.  Also for the phone mount too please - THANKS!
dhaile
« Reply #4 on: January 18, 2016, 10:20:19 PM »
I ordered this and think it will be real nice.
http://www.ebay.com/itm/221513881120?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Andy816
« Reply #5 on: January 19, 2016, 03:45:13 AM »
Dhaile got the link for the USB charger, here's the phone mount:
http://www.amazon.com/iOttie-Holder-iPhone-Samsung-Galaxy/dp/B00FXSU43W
My phone maxes out the width of the clamp, making it fit very securely. I haven't tried it with a smaller phone, but I think it would hold on fine. I'll try a smaller phone when I get the chance.
Also, if you want to mount the USB charger further up the handle bar, you may have to extend the wires, since they're almost maxed out the way I routed them. That should be pretty easy though.
« Last Edit: January 19, 2016, 03:47:28 AM by Andy816 » Logged
woofred1832
My Valkyrie
northern Ill near fox lake
« Reply #6 on: January 19, 2016, 05:27:04 AM »
Its always nice to add the things to the bike to make it your own...... I did the same.... but the best thing is the motor!  Thats the main reason I got the bike, otherwise I was very happy with the 1500 Valkyrie I had, but when I rode the 2014 1832 there was no dought in my mind I wanted it.....now with the things I have added I have a bike that will do me for the rest of my life.....and then give it to my grandson so he can enjoy cruising and the power... who knows by then if they dont make anymore it might be a colectors bike!,,,,,
« Reply #7 on: January 19, 2016, 07:35:55 AM »
Mine was on its way to being someone else's, until I managed to get the handlebars
comfortable and the windshield decent...
Now I love it...
Good luck with those Rivco hiway pegs, I didn't much like mine...
« Last Edit: January 20, 2016, 04:25:15 AM by hubcapsc » Logged
FormerVTXRider
« Reply #8 on: January 19, 2016, 07:51:15 AM »
This looks identical to yours Andy and is located in St. Louis vs International.
http://www.ebay.com/itm/Motorcycle-12V-Cigarette-Lighter-2-USB-Power-Port-Outlet-Charger-for-iphone6-GPS-/221596688334?hash=item3398311fce:g:IgoAAOSwBP9UWt7C&vxp=mtr
Thanks!
dhaile
« Reply #9 on: January 19, 2016, 08:02:50 PM »
Yeah, I wish I had saw that one.  Local is always better.
