January 29, 2026, 06:20:05 PM
98 valk 12K miles, low rpm engine miss
Topic: 98 valk 12K miles, low rpm engine miss (Read 1851 times)
karmann
September 14, 2009, 08:32:58 AM »
Hello Al
My bike developed a low RPM miss ( chug chug) over the weekend, from 2K rpm's up it runs fine, gas is good, At idle you can smell some raw gas in the exhaust.
Help, Where do I start?
Thanks Steve
Re: 98 valk 12K miles, low rpm engine miss
September 14, 2009, 08:48:14 AM »
Run a can of seafoam......full can in full tank.
Also, look at spark plugs. Just replace them if they are original, if vacuum hoses have never been replaced, they are cracked-replace them too, check intake clamps lowers and uppers for loosness and then air cleaner, how long since new?
Those are the majority of simple things I can think of that I would do before starting anything deeper.
Sharkey
GOT CURVES??
VRCCDS0184
September 14, 2009, 02:34:40 PM »
Everything chris suggests. It sounds like your slow jets are clogged. Try the seafoam or techron to see if it helps.
