November 26, 2025, 09:21:12 PM *
Author Topic: What stripper will achieve this result  (Read 1525 times)
RDKLL
VRCC #1231 VRCCDS #271
Mesa, AZ
« on: February 09, 2016, 08:19:29 AM »
Thanks in advance:
Momz
ABATE, AMA, & MRF rep.
« Reply #1 on: February 09, 2016, 01:15:33 PM »
Bodacious Betty can make you strip....... 2funny
ALWAYS QUESTION AUTHORITY!
« Reply #2 on: February 09, 2016, 01:40:37 PM »
Saw a picture of that on facebook and wondered the same thing.  Anyone know what was used?  It would sure make polishing things easier.
da prez
Wilmot Wi
« Reply #3 on: February 09, 2016, 04:30:51 PM »
Starbucks coffee
hukmut
Stone County, Mississippi
« Reply #4 on: February 09, 2016, 04:42:18 PM »
Ha Ha!! Nice one, DaPrez!  Grin
I have read somewhere that there is an   "aircraft paint stripper" available that will remove clearcoat etc.
Don't know where to get it.
Ride safe.
« Reply #5 on: February 09, 2016, 04:58:49 PM »
Candi at the Kit Kat Club can achieve just about any results.  coolsmiley (sorry) Why do you want to remove the clear coat ? I love my wheels and pumpkin on my '01
« Reply #6 on: February 09, 2016, 05:32:11 PM »
Don't know the answer about a specific stripper, but I bet it is an alkali type, which makes it water soluble.
If you are trying to remove clear coat, how about old brake fluid? Everyone has a bottle or 4 sitting around, left over from a top up, that shouldn't be used because it's an open bottle.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #7 on: February 09, 2016, 05:34:44 PM »
According to the fb post it is methylene chloride  based stripper. I search for this on eBay and found it. Appears to be pretty nasty stuff.
So many roads, so little time
VRCC # 5258
« Reply #8 on: February 09, 2016, 05:37:15 PM »
I've tried brake fluid, doesn't touch it.  The aircraft stripper I have seen in auto parts stores.
Haven't seen Candi or the kit kat klub.
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #9 on: February 09, 2016, 07:08:52 PM »
I remember back in the late 80's early 90's I worked selling automotive parts and refinishing business.   There was a product called Kleen Strip Aircraftpaint remover, holy stripper batman (sorry Candi or Kit Kat Club) I see that it is still made, but knowing how the E.P.A. (Employment Prevention Agency)  has changed formulas for most of the products in the automotive chemical industry.
Here's what I've found.
http://www.kleanstrip.com/product/aircraft-paint-remover
Ride on.
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
big poppa pump
San Antonio, TX
« Reply #10 on: February 09, 2016, 08:58:45 PM »
I can vouch for the Aircraft Paint remover. Wear a face mask and gloves before you handle any, that $hit smells nasty. Use a paint brush and apply liberally, leave it on for about 10 minutes and almost everything bubbles off. Use 0000 steel wool and GLOVES and scrub off the clearcoat. Repeat if necessary one more time. Clean up with water.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #11 on: February 10, 2016, 08:25:04 AM »
Aircraft paint remover is what I use . It is made by klean strip
« Reply #12 on: February 10, 2016, 02:21:01 PM »
And how good is it? One application. Will it etch the aluminum case too?
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #13 on: February 10, 2016, 03:38:49 PM »
I use it on triple clamps and forks
No problem you can even rinse with water
Pappy!
Central Florida - Eustis
« Reply #14 on: February 10, 2016, 04:08:53 PM »
I have stripped paint completely off of boats. Quite a big job. I tried the aircraft stripper and that stuff will eat you alive. Even with gloves and a mask. Anywhere it touches gets burned. Nasty stuff.
Something that I found that works very well is a soy based stripper and available through Sherwin-Williams. It does not burn you and works in around 15 minutes or so on pretty much whatever paint is out there except epoxy.
Joevalk
Santa Fe, Texas
« Reply #15 on: February 10, 2016, 07:23:09 PM »
AutoZone sells a clear coat stripper that works well. Spray on, let dry, and blow off with compressed air.
Don't go overboard with the stripper and blow wording uglystupid2
VRCC#32720
1999 Grn/Silver Interstate
« Reply #16 on: February 10, 2016, 07:42:14 PM »
I feel like Johnny Carson to your Ed McMahon.  Smiley
« Reply #17 on: February 11, 2016, 07:29:04 AM »
"Easy Off" oven cleaner will replicate that quite well.
