January 29, 2026, 06:18:36 PM *
Author Topic: Changing the universal joint on a "97 Standard" Big job?  (Read 1847 times)
Bonzo
« on: September 15, 2009, 02:12:53 PM »
I would appreciate any comments or help. I read most of the "Tech Advice".
Took a long ride tuday and heard a slight clunk wheb I would pick up the throttle. after slowing down or clutching
Woops, I'm sorry.
Daniel Meyer
The State of confusion.
« Reply #1 on: September 15, 2009, 03:10:57 PM »
Not a big deal at all. Couple hours work.
http://www.rattlebars.com/mtz/ujoint.html
CUAgain,
Daniel Meyer
Bonzo
« Reply #2 on: September 15, 2009, 03:39:42 PM »
Danny, parts # 13 &  9 do not  have to be removed?
Woops, I'm sorry.
Daniel Meyer
« Reply #3 on: September 15, 2009, 04:57:22 PM »
Nope. They do not. Pull the rear end/shaft, pull the brake resevoir out of the way, push the boot back, push the ujoint off the engine into the swing arm, drop the swing arm, and the ujoint will come out in that space where the brake resevoir is.
The hardest part of the job is getting the durn boot back on. New ones are easier and they only cost $8 so I recommend a new one.
Biggest trick is getting the shaft back into the joint...put the joint on the rear engine shaft, install the boot, then left the swing arm ABOVE horizontal. Shove rear end with shaft in, wiggle till 4 bolts start into the swing arm...then shake it till it slams home. Cant' miss.
CUAgain,
Daniel Meyer
Rocketman
Seabrook, Texas
« Reply #4 on: September 16, 2009, 05:09:05 AM »
Can a job that was described with both "hardest part" AND "Biggest trick" in the description really be described as "Not a big deal at all"?
I understand where you're coming from.  I'm just pokin at ya.
It's one of those "if you hold your mouth just right" jobs that's really easy if you DO hold your mouth just right.
