February 11, 2026, 01:46:58 PM *
Author Topic: Air box queston  (Read 932 times)
fiddle mike
Nothing exceeds like excess.
Corpus Christi, TX
« on: February 12, 2016, 01:20:43 PM »
Does this serve a purpose?
WintrSol
Florissant, MO
« Reply #1 on: February 12, 2016, 01:42:34 PM »
If I recall correctly, that's the drain for any water/oil that is separated from the crankcase breather tube.
fiddle mike
Corpus Christi, TX
« Reply #2 on: February 12, 2016, 01:57:33 PM »
Thanks.
I'm trying to chase down a vacuum leak.  Decided to start over with a different air box.
The bike is de-smogged and I removed the crankcase vent plumbing. Couldn't remember what that third nipple is for.
da prez
Wilmot Wi
« Reply #3 on: February 12, 2016, 03:03:46 PM »
S O M E  will leak at the pair valve mount holes , tho it is  not common. Check the intake connections , clamps and o rings.
 If running , a whiff of eather or  wd 40 will change the engine  speed
                           d.prez
Steel cowboy
Spring Hill, Fl.
« Reply #4 on: February 13, 2016, 04:11:49 AM »
I would also check the manifold's were they bolt to the head. Any brown coloring would indicate a vacumm leak. My O-rings were flattened out I replaced them with Vitron-GT sold on EBay they are about $15.50 with shipping.
2001 black interstate
2003 Jupiter Orange wing
