February 11, 2026, 01:46:53 PM *
Author Topic: Help finding Link/Tool to hold output shaft on reassembly and torque  (Read 785 times)
valknomad
North idaho
« on: February 16, 2016, 08:37:55 PM »
Hydrolock caused tear down of bike. I already have the 32mm socket, 46mm (Clutch) and 36mm (Output Shaft). Starting to Re-assemble,  just can't find the Link or (work around tool)  to hold "Output Shaft" while torquing.
Manuel states "special tool".   Also states 125 ft lb (Indicated) 137 ft. lbs (Actual)... is this correct?  Thank You
« Reply #1 on: February 17, 2016, 05:20:14 AM »
Find the special tool part number in the manual. Put that number in google.
A ton of places will come out. Probably some of them will be boat places.
I got a whole bunch of Honda special tools (but not the one you need)
that way.
« Reply #2 on: February 17, 2016, 06:02:54 AM »
u can make your own tool with a 2x4 and some bolts. an impact wrench will make it much, much, easier to do.
http://www.valkyrieforum.com/bbs/index.php/topic,30038.0.html
make sure u follow the tech manual for lbsft.
using a clicker type torque wrench?, when was the last time it was calibrated?  a beam type or digital is the way to go.
valknomad
North idaho
« Reply #3 on: February 17, 2016, 07:24:23 AM »
The Clutch Basket Assembly/ Shaft is the 46mm / "2x4" tool...
The tool I'm trying to "work around" is to hold the "Output Shaft" / 36mm Locknut.
(it comes off OK with Air Impact Wrench, but Re-assembly... the shaft will need to be held/not spin.)
« Reply #4 on: February 17, 2016, 08:24:43 AM »
I can only guess from your description (you'd know for sure)
that you need a 07jma-mn50100 or a 07jmb-mn50100.
I just googled them up, they're easy to get from a million
different places...
