November 26, 2025, 10:43:24 PM *
Author Topic: LED lights  (Read 1108 times)
raja
Snohomish WA
« on: February 25, 2016, 04:56:48 PM »
Am in the process of switching over to LED bulbs on my 99 Interstate, to save some E juice. Anyone done this? Is there another turn signal module to slow down winker.as there is less draw. ???
Dak44312
Akron, OH
« Reply #1 on: February 25, 2016, 07:30:42 PM »
I've done it on both my Standard and I/S. Don't waste your time or money with standard LED bulbs...they just aren't bright enough. Get the Custom Dynamics panel inserts for front and rear. You'll need the 1156 panels for the rear, and the 1157 panels for the front. Always use the same color LED as the lens color you will be using.
Then go to superbrightleds.com and get yourself an electronic flasher, part # LF1-S-FLAT. Plug and play. While you're on that site, you can also get the #74 bulbs for the cluster, and a #67 for your license plate. I'm trunkless, so can't offer advice on those.
Oh, and by the way... Our alternators are like 6 million amps- incandescents are not taxing the system. If you want to do it because they look cool, are safer, and have great service life, those are the reasons to do it.
« Last Edit: February 25, 2016, 07:43:31 PM by Dak44312 » Logged
WintrSol
Florissant, MO
« Reply #2 on: February 25, 2016, 07:55:06 PM »
You will also have to remove the turn signal indicator, or install a diode pair; otherwise, when one side flashes, they all flash, because the filament in the indicator connects both sides together. To date, they don't make a bi-directional LED that fits in its place.
Dak44312
Akron, OH
« Reply #3 on: February 25, 2016, 07:58:42 PM »
The Interstate does not suffer that issue since it has separate indicators in the cluster. The diode is only needed for Standard and Tourer models.
Paladin528
« Reply #4 on: February 26, 2016, 04:24:36 AM »
Kuryakyn sells a kit for the standard and tourer to correct the issue. It's like $7
WintrSol
Florissant, MO
« Reply #5 on: February 26, 2016, 12:23:44 PM »
Yeah, sorry, I overlooked the Interstate in the OP. Still holds for the Standard and Tourer, though.
big poppa pump
San Antonio, TX
« Reply #6 on: February 26, 2016, 12:48:13 PM »
Why the hell do you want to spend 7 bucks for the diode kit from Kuryakyn when you can get the same product for 2 bucks plus some odd change from superbrightleds.
https://www.superbrightleds.com/moreinfo/motorcycle-accessories/metric-bike-diode-kit/1190/2805/
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
WintrSol
Florissant, MO
« Reply #7 on: February 26, 2016, 06:31:48 PM »
And, if they want to charge more than reasonable postage for a letter, I can just pick it up and mail it to you. They are about 5 mile from me.
big poppa pump
San Antonio, TX
« Reply #8 on: February 26, 2016, 06:37:56 PM »
Superbrightleds is very reasonable when it comes to shipping. First class from shipping from MO to TX was just a couple of bucks. Even with shipping, they're cheaper than Kury!
VRCC#35870
VRCCDS#0266
« Reply #9 on: February 26, 2016, 06:58:11 PM »
I installed an LED flasher on my STD/Tourer and have had zero problems, only one side flashes at a time.
WintrSol
Florissant, MO
« Reply #10 on: February 27, 2016, 11:31:31 AM »
No turn signal indicator bulb, then? Or did you install the resistors?
« Reply #11 on: February 27, 2016, 02:27:36 PM »
still have indicator bulb, no resistors.
just front turns have LED, rear turns are wired with the Electrical Connection led stop lights. front LED caused very fast flash rate, without LED flasher.
