February 12, 2026, 11:11:46 AM *
Author Topic: Balancing beads source.  (Read 3975 times)
« on: March 13, 2016, 05:23:23 PM »
What's a good source other than Loves Truck Stop(too far away)?  I have some in my "stash" but not enough for a c/t. I've heard Walmart carries something similar but thinking it might be for an air gun. Anybody have experience with them, or another type?
pancho
Bonanza Arkansas
« Reply #1 on: March 13, 2016, 05:33:39 PM »
Check eBay Stuffy,, that's where I buy mine.
http://www.ebay.com/itm/Tire-Balancing-Beads-4-bags-of-4-oz-Tire-Beads-16-oz-total/262321723895?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D35852%26meid%3Da7bcd3c0899d471d855607e3ba51ebc5%26pid%3D100005%26rk%3D2%26rkt%3D5%26sd%3D322020347705
Steel cowboy
Spring Hill, Fl.
« Reply #2 on: March 13, 2016, 05:34:44 PM »
I use them on all my bikes. I get them from eBay. I use about 3oz in the back and 2oz in the front. I don't use imitation glass or plastic air soft B/B. I never had any issues with Dyna Beeds.
You just can't mix them with stop leak or any other form of tire fix a flat.
« Last Edit: March 13, 2016, 05:37:23 PM by Steel cowboy » Logged
2001 black interstate
2003 Jupiter Orange wing
« Reply #3 on: March 13, 2016, 05:40:48 PM »
John-I've switched over to good ole Daisy B Bs. Put them in last year and 13000 miles ago and still rollin free!  cooldude RIDE SAFE.
« Reply #4 on: March 13, 2016, 06:14:50 PM »
I just ordered a four pack kit(12oz. total) off Amazon, $25.96 w/free shipping. Should be here midweek, just about the time I'll be putting the bike back together. The 12oz. should give me enough to last the rest of my biking years.  Wink
Dennis, aren't those BB's too large to fit through the valve stem?
« Reply #5 on: March 13, 2016, 06:23:26 PM »
Sorry John, you posted before I could find this.
You can get them in five pound jars here. $60 plus shipping.
Got mine! Grin
Thanks to BonS for this find.
"The following is from an email I received from Quackenbush Co. I talked and ordered from Tom Weiss.
The beads they are buying are our QBZ-58A, which is made of zirconium silicate. ZY beads are made of yttrium stabilized zirconia, and they cost a lot more. We can offer our 0.8-1.0 mm QBZ-58A for the price of $60.00 per quart. A quart contains a little over 5 lbs. We have the beads (QZ-58A) in stock.
Quackenbush Co., Inc.
Tom Weiss
6711 Sands Road
Crystal Lake, IL 60014 (USA)
Website: www.quackco.com
Ph: 815-479-8900
Fx: 815-479-8890
----- Original Message -----
To: quackco@mc.net
Sent: Tuesday, July 21, 2009 8:28 AM
Subject: 0.8-1.0 ZY beads
I have about three pounds of dynabeads left over.  I ordered a quart from the "real" dynabead inventor.  "innovative balancing" was a client to "Quackenbush Co" who was the original inventor.  I was able to purchase a 2 quarts  (just shy of 10lbs for 130.00 dollars.).  I still have about three pounds left.  The guy at innovative balancing is rude and arrogant, overpriced in my opinion.  And when I called Quakenbush I left a message and Tom called me back and I learned the entire history of how dynabeads were thought up and made.  It was a great conversation and a good ma and pop business is how it started.
Don't waist your time on spending 13 bucks on 6oz when you can buy a quart (5lbs.) for $60 and will last for a really long time.
I bought the 5lbs back in 2010, and have hardly touch the jar.
« Last Edit: March 13, 2016, 06:28:15 PM by gordonv » Logged
« Reply #6 on: March 13, 2016, 06:25:31 PM »
Damn, that's a good price with free shipping  cooldude
« Reply #7 on: March 13, 2016, 06:39:12 PM »
Yup-they won't go thru the valve tem BUT my tire guys machine mounts in the vertical plane so we put em in then air em up.  Wurx slicker then snot on a doorknob!  2funny RIDE SAFE.
« Reply #8 on: March 13, 2016, 07:00:59 PM »
Dyna Bead offered them in a bag. You break the bag open, and throw the whole thing in. After you start driving, the spinning will free the beads, and the bag just spins around inside also.
When you remove the tire, break the bead, you vacuum them up with a panty hose on the end of the vacuum hose, and reuse the beads. You can do this all in the horizontal position.
« Reply #9 on: March 14, 2016, 04:16:27 AM »
Looks like Quackingbush is offering a new .06 size.  Will these fit thru the valve?
pancho
Bonanza Arkansas
« Reply #10 on: March 14, 2016, 05:25:15 AM »
I have put the beads in through the valve stem, but it is a real pain with a lot of tapping with a rubber mallet and fiddling. I mount my tires myself, both bike and car and have figured out that the easiest way for me is to pour them right into the tire while one bead is still broken loose. I only use ceramic beads, they are heavy and will always go to the lowest point whatever orientation the tire and wheel are in. I use a funnel with a piece of clear tubing on it to install the beads.
da prez
Wilmot Wi
« Reply #11 on: March 14, 2016, 05:15:55 PM »
John, Quackenbush is about three miles from me. I wish I would have seen the post sooner. I have the remains of 5 pounds in my shop. You would  have  been  welcome  to  them. I have  done 6 or
                da.prez
« Reply #12 on: March 14, 2016, 05:56:49 PM »
                da.prez
Ross, thanks for the offer, I went ahead and ordered some online, figured they'd get here about the time I'm ready for them. Found I have other work/cleanup to do anyway.
« Reply #13 on: March 14, 2016, 06:08:25 PM »
Next time you might want to check Jake Wilson too.?
https://www.jakewilson.com/p/1753/23684/Dyna-Beads-Refill-Bag?term=dyna+beads
My rides:
« Reply #14 on: November 19, 2018, 09:26:59 PM »
I just got an email today, the company is out of business, as the owners retired. You can read it below.
Quackenbush in Crystal Lake, IL. has recently sold their company and the owners have retired.  Tom Quackenbush has passed along your previous order history to Ceroglass.  I just wanted to pass along my information in case you have any future needs.  My contact information is below.  Please do not hesitate to give me a call if you have any needs for any type of ceramic and glass beads.  I have listed below the different types that we stock in our Tennessee facility.
Sintered Zirconium Silicate
Fused Zirconium Silicate
Cerium Stabilized Zirconium Oxide
Yttrium Stabilized Zirconium Oxide
Glass Beads
We stock over a million pounds of media in our Tennessee facility.  We can ship one pound or a truck load.  The material you received from Quackenbush will be the same exact material yu will receive from Ceroglass.
Please let me know if yu have any questions.  My contact information is below.
Wishing you a successful day.
Teresa Bradley
General Manager
Ceroglass Technologies Inc.
919 North James Campbell Blvd.
Columbia, TN. 38401
Phone: 931-560-4174
Fax: 931-490-8030
Mobile:  931-212-7555
Website:  www.ceroglass.com
E-mail: Teresa.bradley@ceroglass.com
« Reply #15 on: November 20, 2018, 04:57:20 AM »
It took longer than expected for the Amazon shipment to get here so I checked with O'Reilly Auto Parts. Ordered them midday, picked them up after 5:00pm same day, came from their local warehouse. I found most auto parts places around here carry them but you might have to wait a day since they usually don't have them as shelf stock.
« Reply #16 on: November 20, 2018, 06:45:52 AM »
          One other point of interest when I use BBs. The BBs do NOT have any fine particles that plug the tire valve when checking tire pressure. I plan on doing all 4 corners on my new to me 06 Pontiac-BBs as the balance media. I'll check with Ross and find out whether or not he knows bout Q bush goin outa business there in Crystal Lake. RIDE SAFE.
kodiakfisher
Beaverton, OR
« Reply #17 on: November 20, 2018, 08:32:51 AM »
It may be worth noting that I have had balancing media stick in my valve stems causing a leak even after making sure the valve stem is at least at 90 degress and being tapped on. I now never check my tire pressure unless sitting at an air pump.
I do like the idea of BB's so they don't get plugged in the valve stems but alas you can't put them in through the valve stems. I suspect most of us choose a balancing method during tire changes though and after that forget about it.
CleoBen
2000 Interstate
Lewisburg. Ohio
« Reply #18 on: November 22, 2018, 06:35:28 AM »
Any reason to NOT use the Crosman ASP512 AirSoft BBs (.12G 6mm, Red BBs)?  If they will work, how much should I put in the rear (CT going on) and front?
CB
« Reply #19 on: November 22, 2018, 03:17:35 PM »
Airsoft ammo available at any Wally World . Cheap postal ( pot ) scales available at any Indian owned quickie market ( not the native American Indian the other kind ) . 2 oz motorcycle tire / 3 oz car tire . Been using them for years so has all my local riding buds.
« Last Edit: November 22, 2018, 03:20:21 PM by Smokinjoe-VRCCDS#0005 » Logged
Momz
ABATE, AMA, & MRF rep.
« Reply #20 on: November 25, 2018, 04:49:09 PM »
Yep!    cooldude
ALWAYS QUESTION AUTHORITY!
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #21 on: November 26, 2018, 06:14:29 AM »
I get mine thru quackenbush and I buy 5lbs for 60.00
http://www.quackco.com/tirebalancingbeads.html
« Reply #22 on: November 26, 2018, 04:52:22 PM »
AR, you missed my last post  Smiley , they are all retired now, and the info has gone over to another group.
I found the email they had just sent me last week;
Glass Beads
Teresa Bradley
General Manager
Columbia, TN. 38401
Phone: 931-560-4174
Fax: 931-490-8030
« Reply #23 on: November 06, 2021, 09:24:48 AM »
Another email, inquiring if I wanted to make a purchase.
Note:
In the past, you purchased our 0.8 mm zirconium beads (QBZ-58A) through Quackenbush. When Tom retired a couple years back, he shared your information with us.
I just wanted to check in to see how your bead supply for your MC tires is holding up and see if you were ready to re-order. Our product name for these beads is ZS-9309. These are in stock. Price is $9/lb. plus shipping from Columbia, TN. We would be happy to check shipping charges – would just need to know the quantity you are interested in.  You purchased a quart in the past (5.18 lbs.) – we would round this down to 5 lbs. - $45 plus shipping.
Please don’t hesitate to reach out with any questions. We are always happy to help.
Thanks so much, Gordon. Have an awesome weekend, and Happy Halloween!
Very Best,
Olivia Lovvo
General Manager
Ceroglass Technologies, Inc.
919 N. James Campbell Blvd.
Columbia, TN 38401
Main 931-490-8030
Direct 931-560-4175|Cell 727-465-4003
Fax 931-490-8060
« Reply #24 on: November 06, 2021, 12:04:29 PM »
Anybody ever use balance beads in a low profile car tire used on a 4-wheeler. My SUV apparently has a wheel they can't seen to balance right and still has a vibration at speed. I was told some time back that beads don't work well with low profile tires which mine also happen to have the pressure monitoring system.
Rio Wil
« Reply #25 on: November 06, 2021, 02:09:00 PM »
Six shotgun shells, one ounce each of #7 steel shot, three in the front, three in the back. Pour down the valve stem.....check first to see if the valve stem is large enough diameter. Use a small diameter plastic hose  with a funnel small enough to cause the shot to run down the tube in single file. Tilt the valve stem up to facilitate the shot going down the valve stem...... Can't believe I wasted so much time balancing tires with weights...... crazy2
Avanti
Stoughton, Wisconsin
« Reply #26 on: November 06, 2021, 02:28:56 PM »
I would think that the steel shot would rust and clump together.
« Reply #27 on: November 06, 2021, 02:52:54 PM »
PITA with a 90 degree valve stem.
BB's are easy to put in the new tire.
Rio Wil
« Reply #28 on: November 06, 2021, 05:22:55 PM »
Thats why you turn the valve stem pointing upwards....the little bb's just scamper right through..
Doubt there is enough humidity in a tire full of air to rust them, besides they have a sort of gray coating from the heating process and the constant tumbling would keep them from clumping. BTW "steel shot " is made from a variety of metals::::
Bismuth-tin    97% bismuth, and 3% tin
Iron (steel)    Iron and carbon
Iron-tungsten    Any proportion of tungsten, and >1% iron
Iron-tungsten-nickel    >1% iron, any proportion of tungsten, and up to 40% nickel
Tungsten-bronze    51.1% tungsten, 44.4% copper, 3.9% tin, and 0.6% iron, or 60% tungsten, 35.1% copper, 3.9% tin, and 1% iron
Tungsten-iron-copper-nickel    40–76% tungsten, 10–37% iron, 9–16% copper, and 5–7% nickel
Tungsten-matrix    95.9% tungsten, 4.1% polymer
Tungsten-polymer    95.5% tungsten, 4.5% Nylon 6 or Nylon 11
Tungsten-tin-iron    Any proportions of tungsten and tin, and >1% iron
Tungsten-tin-bismuth    Any proportions of tungsten, tin, and bismuth.
Tungsten-tin-iron-nickel    65% tungsten, 21.8% tin, 10.4% iron, and 2.8% nickel
Tungsten-iron-polymer    41.5–95.2% tungsten, 1.5–52.0% iron, and 3.5–8.0%
Just out of curiosity, does the copper coating on BB's get ground off after a while.....
Avanti
« Reply #29 on: November 06, 2021, 05:53:18 PM »
Good question.
pancho
Bonanza Arkansas
« Reply #30 on: November 06, 2021, 06:47:07 PM »
I switched from beads to BB's a couple of years ago when I ran out of beads. I have broken down and changed a couple of tires (car, truck and MC) and found the BB's to be gray color instead of copper. No appreciable copper dust and no rust on the BB's. They are not shiny as you might expect, but dull gray, so I assume they take a light beating quite often in use.
« Last Edit: November 06, 2021, 06:51:57 PM by pancho » Logged
« Reply #31 on: November 07, 2021, 05:09:03 AM »
I've used BB's for a long time. I've seen them at a tire change and they look the same. No "dust" inside the tire.
Some do like to overthink stuff.
SCain
Rio Rancho, NM
« Reply #32 on: November 08, 2021, 05:57:47 AM »
Here is another Balancing Bead, I have never used them.
https://checkeredflagtirebalancebeads.com/
Steve
« Reply #33 on: November 08, 2021, 06:32:23 AM »
I don't know the total weight but you get 6,000 for under $8
https://www.walmart.com/ip/Daisy-Precision-Max-BB-s-0-177-Caliber-BB-Zinc-Plated-Steel-6000ct/15729973
Doug B.
Cadott, WI
« Reply #34 on: November 09, 2021, 02:34:53 AM »
A bit further down on the page....4.575 lb.
« Reply #35 on: November 09, 2021, 05:39:47 AM »
Thanks.
Rio Wil
« Reply #36 on: November 09, 2021, 01:47:02 PM »
That's kinda what I would expect and there is not enough copper liberated to show any trace inside the tire.....not that it would matter anyway.....just curious... coolsmiley
