November 27, 2025, 01:39:09 AM *
Author Topic: 44 mm fork tool ?  (Read 1223 times)
Brian
Monroe, NC
« on: March 15, 2016, 03:10:07 AM »
Hello DYI'ers,
I am going to rebuild the forks due to seal leaks. I have done the seal mate trick that got me an extra year and half of riding. The same seal is leaking again, time to replace them. I am also going to try the Progressive springs while these are a part. My dilemma is this special socket is $42 from dealer and no luck finding it aftermarket. Can anyone direct me to another source or can this be made at home from a piece of pipe?
Thanks to all.
« Reply #1 on: March 15, 2016, 03:39:03 AM »
u can make your own fork tool from heater element wrench $8 home depot
http://www.valkyrieforum.com/bbs/index.php/topic,70292.0.html
here are the dimensions of the honda tool.
http://rattlebars.com/vtx/forktools.html
and make a stem nut tool
http://www.valkyrieforum.com/bbs/index.php/topic,31752.0.html
Brian
Monroe, NC
« Reply #2 on: March 16, 2016, 02:54:53 AM »
Thank you sir. This info would not pull up for me using the search feature here. I sure appreciate it.
Bagger John - #3785
« Reply #3 on: March 18, 2016, 05:44:07 AM »
If any VRCCers living in the Ohio/WPA area need a fork rebuild done, get the parts and get in touch. I have all the required tools and will travel/work for food...  Evil
