crash1980
« on: March 15, 2016, 06:44:20 PM » |
My cut off switch on my right handle bar control is giving me problems. Something inside the switch is broken. I noticed this when I installed my risers and had to take it apart to re-route my throttle cables. It has be kinda touchy but I noticed it more so yesterday. If I kinda bump it it will kill the bike and I can usually wiggle it a little and it will roar back to life, but yesterday I had to come to a complete stop once to play with it enough to make it work again. Is there any way to repair this or will I have to buy the whole right hand assembly?
« Reply #1 on: March 15, 2016, 06:48:45 PM » |
I've never had to mess with mine as I rarely use it. But many here have recommended taking it apart and cleaning it.
« Reply #2 on: March 15, 2016, 08:17:50 PM » |
I actually don't recall anyone confirming that they have ever had a problem with the kill switch. Many think that it was, but upon further searching, found it to be something else.
Doesn't mean there can't be a 1st.
Like suggested, look into taking it apart. I would start by doing a search, and seeing all you can on the kill switch.
Because I don't think there is anything on it, please document your repairs. Would make a nice post for future reference.
I know that the starter switch can only be had as a new unit, it would make sense that the kill switch would be the same. Check used ones. I almost never use the kill switch, and would think the same for most, so would be one of the most unused items on the bike.
Captain Combat
« Reply #3 on: April 21, 2016, 07:36:50 PM » |
Well... I can confirm. I don't even touch my kill switch on my 97 Tour. It has a BAD switch. If I touch it, it kills the bike. Not switch it... Touch it. I learned this fueling up one day and it took me 20 minutes to figure out if I push and wiggle, and cuss at it, it'll fire up.
My start button works like a champ. It's the kill switch that's messing up.
I have a wrecked VTX in the garage. Wonder if I can use that switch...
« Last Edit: April 21, 2016, 07:38:23 PM by Captain Combat »
« Reply #4 on: April 22, 2016, 05:35:37 AM » |
Probably.
pancho
« Reply #5 on: April 22, 2016, 06:20:02 AM » |
Since I never used the kill switch, I bypassed it in the headlight bucket and used the switch to toggle the relay for the running lights. There was something tricky about wiring it like that, but I don't remember what it was off hand.
« Reply #6 on: April 22, 2016, 07:42:34 AM » |
Hey guys....especially Pancho and Captain Combat. The kill switch is an important safety device, required if you have an annual inspection.
I would think it's ill advised to disable it, but that is your choice. If it's broken, order a new one, simple.
pancho
« Reply #7 on: April 22, 2016, 07:48:42 AM » |
No inspections in my neck of the woods,, they were done away with a few years ago. I never used it for it's intended purpose (don't really understand it with a key and tip over sensor) so I put it to another use. But after seeing your comments Chris, I think I will change it back if I ever give the bike to anyone else.
« Last Edit: April 22, 2016, 07:50:50 AM by pancho »
Lyle Laun
« Reply #8 on: April 22, 2016, 02:38:08 PM » |
One of my Valks has a "touchy" kill switch. I never use it but occasionally I have to wiggle it to get it to start. I've had it apart and cleaned but that didn't appear to help any. I've got a new one from having to buy the complete item to get a new start switch, just haven't bothered putting it on. I would think that there should be quite a few new ones available here as so many of us have had to buy the complete housing just to get a new start switch. Maybe try posting a WTB in the classifieds.
Lyle
Get out & Ride !! 97 Red/White Standard dressed as Tourer 98 Black "Rat Rod" Standard 99 Green/Silver Interstate
Bubba FoSho
« Reply #9 on: April 22, 2016, 03:34:56 PM » |
I use my kickstand to cut my bike off. I hardly ever use the kill switch mainly because I don't think about it when I park my bike.
« Reply #10 on: April 22, 2016, 05:52:41 PM » |
I never use the kill switch, I kill it just like my truck... With the key. Every year in Daytona in our parking lot at least one bike had a dead battery from the kick stand method
saddlesore
« Reply #11 on: April 22, 2016, 07:18:29 PM » |
When I replaced my starter switch the kill switch was connected to the same harness. My memory tells me that's true but I tried to confirm it but found no definitive proof. If you have to replace the starter switch (like me) you do the kill switch at the same time.
DARE TO BE DIFFERENT
Wayn-O
« Reply #12 on: April 22, 2016, 09:21:34 PM » |
I can confirm that my kill switch also behaves the same way. It functions when I switch it, but will also kill the bike if I touch or press on it without switching it. Found this out after state safety inspection. I, like many of you, never use the kill switch (except during inspections or in a hypothetical emergency) however I don't like the finicky-ness of this... Would be nice to get a solid answer if cleaning it or something can remedy. Don't really want to spend money to replace the entire housing or a silly switch.
2000 GL1500C Valkyrie 2003 VT1100C Shadow Spirit 1998 VT1100C Shadow Spirit 1983 VF750C V45 Magna
« Reply #13 on: April 23, 2016, 05:31:04 AM » |
I can confirm that my kill switch also behaves the same way. It functions when I switch it, but will also kill the bike if I touch or press on it without switching it. Found this out after state safety inspection. I, like many of you, nevetvhomer use the kill switch (except during inspections or in a hypothetical emergency) however I don't like the finicky-ness of this... Would be nice to get a solid answer if cleaning it or something can remedy. Don't really want to spend money to replace the entire housing or a silly switch.
As long as you know how to bypass it so if it messes up, you can still get home. I would get to far from home otherwise
John larsen
« Reply #14 on: April 25, 2016, 07:15:20 PM » |
Speaking of switches, I suspect trouble w/my starter switch on 97 tourer. Hit the switch an click or 2 then engine turns over. Battery 8 Mos old and contacts clean and fully charged. Seems I had switch problems on 97 Shadow and they look identical. One of you said there are contacts to clean in the switch?
Wayn-O
« Reply #15 on: April 25, 2016, 08:02:15 PM » |
http://www.valkyrieriders.com/shoptalk/VSGPages/starterbutton.htm
