November 27, 2025, 12:17:09 AM *
Author Topic: Frozen brake pad pin  (Read 1031 times)
joker
New York
« on: March 17, 2016, 10:21:49 AM »
Well I went about changing my brakes in the front. one side was no problem at all. However the right side was completely Frozen,  the cap as well as the pin. I had to drill out the Allen head on the  pin. I'm bringing home an assortment of cotter pins and we'll use that as the pin. I'll let you know how it goes.
« Reply #1 on: March 17, 2016, 11:51:17 AM »
If a correct pin cannot be refitted, buy a new caliper (used) they are not that expensive.
« Reply #2 on: March 17, 2016, 12:17:20 PM »
« Reply #3 on: March 17, 2016, 02:09:17 PM »
Wouldn't asking someone called Joker if he is serious be considered rhetorical ?
Joker, I think they are trying to tell you this sounds HIGHLY UNSAFE.
« Reply #4 on: March 17, 2016, 03:38:12 PM »
http://www.ebay.com/itm/99-Honda-GL1500-GL-1500-C-Valkyrie-front-brake-calipers-right-left-set-/311497534835?hash=item4886b32d73:g:Gn8AAOSw8-tWXuIk&vxp=mtr
What Chris said.
$60.00 buys both, others are cleaned up going for around $50.00 each.
« Reply #5 on: March 17, 2016, 05:05:17 PM »
In the future, a 50/50 mix of acetone and ATF is the best rust penetrant there is. Let soak and retry the bolt/nut.
flash2002
Montreal, Que
« Reply #6 on: March 18, 2016, 02:19:02 AM »
That reminds me of a old wing I bought. When I took it apart there were wood screws in place of bolts, nails instead of carter pins and plywood as spacers.  Shocked
joker
New York
« Reply #7 on: March 18, 2016, 05:34:40 AM »
Ahhh, I miss that old Wing.  Haha. Just kidding.
joker
New York
« Reply #8 on: March 18, 2016, 05:37:53 AM »
I'm not a proud block head. If others have a good idea, or think something is unsafe, I will listen. Thanks guys. I didn't know you used ones would be so inexpensive. I guess I should have looked.
« Reply #9 on: March 18, 2016, 08:18:03 AM »
cooldude I know I've learned many things from the guys here.
« Reply #10 on: March 18, 2016, 04:20:13 PM »
Grin Grin Grin cooldude
WoodyFL
Ocoee, Fl
« Reply #11 on: March 19, 2016, 10:14:53 AM »
Just had the same thing happen to me. Both pins were froze solid. Bought an EZout set and had to use that to remove the pins. Ordered new pins and caps from Partzilla.
Bob
2000 Blue/Silver I/S
Ocoee, FL
