April 29, 2026, 09:47:40 PM *
Author Topic: Removing Passenger handles  (Read 2821 times)
Stanc770
« on: March 27, 2016, 03:21:14 PM »
Just ordered kit to cover the pieces taken out when passenger handles removed. My question is, the bolts removed, are they retained for keeping fender intact? and the best way to remove the current inserts. Hope to have replacement panels by Wed.
Most everything I have removed has tabs or push pins, this seemed a little tighter than normal so I thought I would ask someone that has done this.
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #1 on: March 27, 2016, 04:48:58 PM »
Answer is no.  The four bolt holes will be left open the blanks are three screws each for each blank inserted while the fender is upside down.    You will keep the bolts in a safe baggy or something for the day you might go back for bags or whatever.
Stanc770
« Reply #2 on: March 28, 2016, 08:12:21 PM »
Thanks for the reply. Have a container that I keep all parts I remove for future replacement.
Saw the picture of your bike with this modification and really liked it.
