November 27, 2025, 01:37:20 AM
Bad clutch or not
Topic: Bad clutch or not (Read 896 times)
dvldg
Lake Mary fl
Bad clutch or not
March 28, 2016, 06:37:31 PM »
Has anyone had this happened ?
1999 standard, the clutch works perfect , no slipping. And it goes in every gear with no problem, except when I come to a stop i leave the bike in gear, after a minute or so the bike starts taking off while Im still holding the clutch level in.
Ceasar
(Jarhead)
allanbegg
Marietta, PA
Re: Bad clutch or not
March 28, 2016, 06:43:37 PM »
Sounds like the Clutch Master Cylinder needs rebuilt.
You are "slowly" losing pressure in the line while sitting there, and it is allowing the clutch to re-engage.
Allan
VRCC # 36795
dvldg
Lake Mary fl
March 28, 2016, 07:09:46 PM »
Thank Allan!
Is it cheaper to just get a new master Cylinder?
Ceasar
(Jarhead)
March 28, 2016, 07:36:16 PM »
Could it be as simple as just needing a flush? Fresh oil and removal of any contaminants that might be causing problems of the master cylinder plunger.
March 29, 2016, 05:14:35 AM »
My first suggestion also would be to change the fluid and give it a good bleeding.
dvldg
Lake Mary fl
March 29, 2016, 06:35:25 AM »
I changed the slave cylinder, thinking that maybe that was the problem and flushed it.
Ceasar
(Jarhead)
dvldg
Lake Mary fl
Reply #6 on:
March 29, 2016, 07:03:52 AM »
The slave cylinder was leaking but I ready rebuilded but that didn't fix the problem .
Ceasar
(Jarhead)
Reply #7 on:
March 29, 2016, 08:21:40 AM »
If the clutch lever works smoothly, freely and has full travel, and the clutch assy engages smoothly then I doubt there is anything wrong with the clutch itself. If it is starting to get 'jerky' upon release of the lever then there may well be a few sheared rivets. If that isn't happening then I would think there is just a hydraulic issue somewhere. Flushing and changing fluid means different things to different folks. Some folks have had a hard time getting all the air out of the system. There is also the possibility of a bad cylinder. I just think a good flushing at first is a good place to start.
=> InZane XXV
