February 11, 2026, 08:39:14 PM *
Author Topic: ignition 30 amp red fuse  (Read 1003 times)
« on: March 30, 2016, 04:58:58 PM »
I know several of you guys have had this problem with that red fuse melting under the right side cover. I'm trying to find a replacement for my brothers 97 because his melted. I'm having no luck finding one. Any info would be greatly appreciated.
Firefighter
Harlingen, Texas
« Reply #1 on: March 30, 2016, 05:31:02 PM »
Mine was the starter relay with fuse, I fixed it then ordered one from Partzilla for 30.00.
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
« Reply #2 on: March 30, 2016, 05:41:04 PM »
Are you referring to the ignition relay fuse?
http://www.valkyrieforum.com/bbs/index.php/topic,16445.0.html
« Reply #3 on: March 30, 2016, 06:19:48 PM »
I direct wired mine when the connector melted.....I'll see if I can find the post
« Reply #4 on: March 30, 2016, 06:46:03 PM »
http://www.valkyrieforum.com/bbs/index.php/topic,74229.0.html
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #5 on: March 30, 2016, 06:49:43 PM »
I bypassed that poorly engineered blade connection years ago.  Too much current going through that connector, especially if it gets any corrosion resistance in it.
Buy a cheap, inline fuse holder that is the same size as your 30 amp fuse on your starter relay.  Use a crimp eye connector and connect one end to the screw that holds your main 55 amp fuse.  Connect the other end of the fuse holder via a crimp butt splice connector to the red wire that burned off of the left rear of your starter relay.
It's fixed forever.
Save a horse, ride a Valkyrie
BobB
« Reply #6 on: April 04, 2016, 11:20:13 AM »
In 2008, on my first adventure 200 miles away from home on the Valk, I experienced the same problem as Chris, melted the connector above the starter relay.  Solved the issue similar to Chris.
I never replaced the connector as it is part of a much larger wiring harness...
« Reply #7 on: April 04, 2016, 12:56:32 PM »
Thanks guys, I will do this fix.  cooldude
