February 11, 2026, 07:00:38 PM *
Author Topic: Memphis Batwing install  (Read 1217 times)
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« on: April 13, 2016, 06:41:29 AM »
just got a MS Batwing from a fellow member and bought new brackets.
I really just need to see a pic of the bracket on the fairing and the location of the clamps on the forks.
Any tips you can offer to help make the job go smoothly will be greatly appreciated.
 Tony
If you please God it doesn't matter who you displease   but if you displease God it doesn't matter who you please Smiley
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #1 on: April 13, 2016, 11:58:15 AM »
might be easier to take a picture with your phone and text it to me.
850-227-5058
Need to see which way the brackets mount to the fairing
t-man403
Valk-a-maniac
Calgary, Alberta, Canada.
« Reply #2 on: April 15, 2016, 09:47:57 AM »
This is how I did mine. Used a 1" ready rod coupling at the top so that the angle the fairing sits is changed to a more upright position allowing the fairing to fit and sit tighter to the headlight.
This is how it will fit without the coupling ..... okay, but can be better.
http://i936.photobucket.com/albums/ad207/sundaram316/Bike%20rebuild/20141110_184321_zps4fd032da.jpg
This one as well looks good but could fit tighter on top of the headlight IMO.
It is a pretty good fit compared to others I've seen.
http://vrcc.photostash.com/vrcc_29405/DDSCF0002a.jpg
This one is mine ...... no gap between the fairing and headlight. I'm not picking on anybody else' install as I'm sure they are happy with them. I just had a problem myself with the gap, due to the fairing being universal.
https://05qkvw.bay.livefilestore.com/y2pq-pQf1IV-uMOR_4MFO2GkecDNDfsmhdHLn4ifZF_T3QIcsGGLw3ggk41Dxye7nPENOEK90XhqLRg1cQDFqn004NTqBxve7As20R_HgumK44/Batwing.jpg?psid=1
« Last Edit: April 15, 2016, 10:10:14 AM by t-man403 » Logged
csj
Peterborough Ontario Canada
« Reply #3 on: April 15, 2016, 04:07:14 PM »
FWIW, The fork clamps, the two bottom ones. I'm on my third set. The bottom two
keep breaking.
I've had to resort to something redneck to mount the fairing on the bottoms,
much more rugged, looks fugly.
All I'm saying is, watch the bottom two for cracks.
Other than that I like my MS Batwing. It is a universal, so getting it to fit the first time,
good luck.
t-man403
Valk-a-maniac
« Reply #4 on: April 15, 2016, 07:58:56 PM »
keep breaking.
good luck.
My brackets are like new ..... no issues, but, must be lined up properly.
BigBad1
1999 Interstate
Garner NC
« Reply #5 on: April 16, 2016, 12:02:18 AM »
That looks really nice. I wish I had seen that when I had my Tourer.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #6 on: April 16, 2016, 09:18:45 PM »
t-man thanks for the pic's and tips  cooldude    I went to ACE today and got some couplings and washers along with a 2" 1/4 x20 carriage bolt that i used as  studs.  I cut the bolt into 2-  1" "all thread "
The fairing brackets are touching my speedo and tach,  do yours do that?  It is also a tight fit.
 The top clamp is as high as it will go and I have to do quite a bit of wiggling to get the fairing into the brackets.
But there is NO gap between the fairing and headlight.
 I also had to take the top Moto-wings (like Baker Air wings ) off so the fairing lowers won't hit it.
Tommorow I'm going to finish up and try and modify my light bar to fit and wire it up.
Thanks again,  cooldude
  Tony
t-man403
Valk-a-maniac
« Reply #7 on: April 17, 2016, 07:19:03 PM »
  Tony
Your welcome.
You have done the same as I up to this point.
I flipped my brackets to the opposite sides and that gave me clearance off the gauges. It's close but there is clearance and even vibration doesn't effect the clearance. If you have done this already, you could probably make the hole in the bracket oblong so you can gain the clearance you need.
I'd like to see what you do with the light bar so post up a photo or two if you would.
