February 11, 2026, 07:00:36 PM *
Author Topic: SmartSwitch  (Read 1214 times)
F6Ghostrider VRCC #32501
Bakersfield, CA.
« on: April 15, 2016, 07:51:09 AM »
I was off the grid for a bit until recently. I now see the SmartSwitch advertised. I recently replaced my start button for the 2nd time. I've done the whole remove, thouroughly clean and replace with some success.  But, eventually it burns out.
So my question is, has anyone installed one on your Valk, and does it do what they say? For the cost, it certainly can't hurt. If this product does what the ad says, I'm in!
Your thoughts and comments?
Joe Hummer
Arnold, MO
« Reply #1 on: April 15, 2016, 08:15:44 AM »
Hey F6, Sorry, I can't testify first hand knowledge on the SmartSwitch as I have an IS and the SmartSwitch really doesn't help the IS because the headlights are on relays already.  But, I have spoken with BonS about the product and looked at one last fall and I have to say that it is well put together and will operate as specified on the Standards and Tourers.  Taking the load of the headlight off of the starter switch is huge on those bikes.  The added benefit of providing more power to the headlight through larger wire size and a direct feed sure doesn't hurt.  If you have added lights (such as driving lights) tied into your headlight circuit, you are begging for trouble with your starter switch.  This setup will clear up that problem too.  As for installation, it appeared to be a simple plug and play.  Hope this helps.
Joe
1999 Valkyrie Interstate
Bone
« Reply #2 on: April 15, 2016, 08:18:31 AM »
Bought one last November. My headlight sure did light up the garage what a nice improvement Smiley
I wanted to take the heavy load off of the start switch and the Smartswitch is the answer. Very well
made and easy to install. I'm in Michigan so I waited until spring to ride. My mpg stayed the same Sad
BobB
« Reply #3 on: April 15, 2016, 09:14:04 AM »
With the SmartSwitch, Bon has created a nice plug and play method of going what the two relays did when I installed them years ago.  I have not had starter or hi/low beam switch issue since I made the change.  If the SmartSwitch had been available back then, I would have used it...
Bakersfield, CA.
« Reply #4 on: April 15, 2016, 10:35:36 AM »
Sweet! Those are replies I was hoping for.  I haven't seen any crap posted or advertised on the VRCC yet.  I am definitely investing in one now.   cooldude
Thanks for your replies.
Jeff.
BonS
Blue Springs, MO
« Reply #5 on: April 15, 2016, 10:48:50 AM »
You might say I'm a bit biased  Shocked but the Smart Switch will fix you right up. No more melted switches and a brighter, longer lasting headlight as well. It's true that the Interstate has built in relays - so no melting switches, but the headlight brightness and headlamp lifetime will both be improved with the Smart Switch as well. If there's an easier accessory to install it would have to be something chrome!
Fazer
« Reply #6 on: April 15, 2016, 12:56:20 PM »
Quality made and works great.  Easy install.  And he's great to work with.
Nothing in moderation...
slider
mulberry arkansas
« Reply #7 on: April 15, 2016, 01:06:44 PM »
Where at an I get one of these smart switch thangs/?thanks guys
a proud navy veteran
Grandpa Bigbuck
Paola, KS
« Reply #8 on: April 15, 2016, 04:36:49 PM »
Slider, try this.
wwww.thedigisync.com
slider
mulberry arkansas
« Reply #9 on: April 15, 2016, 04:40:28 PM »
thanks for the info
DK
Little Rock
« Reply #10 on: April 15, 2016, 07:57:48 PM »
Ive got both of his switch / relay circuits.
One on my Tourer headlight, the other on my driving lights.
Absolute quality products exactly as advertised.
Dan
Kunkies
Charlotte, NC
« Reply #11 on: April 16, 2016, 05:42:56 AM »
Own a 2000 GL1500CT (Tourer) and installed the SmartSwitch. . . love it.
