February 11, 2026, 07:01:09 PM
ect sensor mod
Topic: ect sensor mod (Read 878 times)
dig66
ect sensor mod
April 21, 2016, 02:41:24 PM »
hi I'm new here , does the resistor mod on the ect make much difference or is trigger wheel better
Re: ect sensor mod
April 23, 2016, 10:39:35 PM »
The ECT mod is cheaper and allows you a variable advance.
The trigger wheel, being purely mechanical, gives a set advance all across the range.
You choose.
wiggydotcom
Yorkville, Illinois
Re: ect sensor mod
April 24, 2016, 05:54:12 AM »
I had a 4 degree trigger wheel on my first Valk Interstate and then did the ECT mod on my last Interstate.
Being an electrician, the ECT mod was pretty simple and I used the pot instead of a fixed resistor.
As Willow said, the advance can be controlled with the ECT mod and even turned on or off.
Some valks are harder to start in cold weather with the trigger wheel.
VRCC #10177
VRCCDS #239
