February 11, 2026, 07:01:11 PM *
Author Topic: Alt. Cover Fix (crinkel prevention)  (Read 1342 times)
PharmBoy
Lawton, Ok
« on: April 22, 2016, 09:24:51 AM »
I discovered this some time ago (back before the price for alternator covers went out of sight).  I started using EVERCOAT part #100116 to reduce the sound of transmission covers by coating the side close to the transmission with the stuff. Having bunches left over, I coated the back side of the alternator cover too.  That was several years ago and haven't had to replace the one on my Interstate yet.  It still looks new.  The stuff has gotten more expensive since then, but there is probably enough material there to cover at least 12-14 alt. covers.  If you have a friend, share.  Works real easy by cutting to size, heating with a heat gun, then removing the cover from the sticky side and pressing into place.  The heat makes it pliable enough to mold into the complex curves of the corners.  Warning-too much heat and you could burn your fingers.  After placing the material you can always add more heat and use a paper towel to press it down.  Oh yes, it won't slide after it's put in place...Jim
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
« Reply #1 on: April 22, 2016, 10:07:52 AM »
Jim, I'm wondering if that would work on the underneath side of the rear fender on my 1200 project. I was just going to spray it with undercoat but maybe this would be a time saver.
This is before I mounted braces on either side, give a better side view.
PharmBoy
Lawton, Ok
« Reply #2 on: April 22, 2016, 11:39:53 AM »
John, I can't see where it would save you any time and would be considerably more expensive since you would have to buy much more material than you would need...Jim
99 Interstate
97 Bumble Bee
97 Red & White
Roidfingers
Tuscaloosa, Alabama
« Reply #3 on: April 22, 2016, 11:54:23 AM »
Im with you on that. Even some of the metal tape for ducting would reflect the heat off. I do know this. When I got my valk last summer my cover was fine. But after installed the chrome trans covers the dreaded crinkle happened. I think that the heat cant dissipate due to the covers and over heats the plastic alt cover and the chrome and copper separate.  Sad I'd like to see how many with no trans covers and with trans covers have crinkled. Bet the latter has way more. especially if you also have the covers for around the ing switch and left area too.
« Reply #4 on: April 22, 2016, 12:35:36 PM »
Both my bikes have the Kury trans covers.  One is pristine on the 55K bike.  The other got wrinkled badly on the 90K bike (and was already started when I bought it with 24K).
Besides gas (or other) spills (which I am skeptical of), I think it is caused by too much sitting and idling on hot hot days.
Could some alternators be hotter than others?  As far as I know, the alternator on my 90K bike is original, and working fine.
big poppa pump
San Antonio, TX
« Reply #5 on: April 22, 2016, 12:57:45 PM »
I installed this under the alternator covers on both my bikes. So far no issues.
http://www.amazon.com/Thermo-Tec-13575-Adhesive-Backed-Barrier/dp/B00029KC2K
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
DK
Little Rock
« Reply #6 on: April 23, 2016, 08:49:29 AM »
Could doing this insulate the cover to the extent that overheating would damage the alternator?
Dan
Steve K (IA)
Cedar Rapids, Iowa
« Reply #7 on: April 23, 2016, 04:50:40 PM »
I still have some of this stuff (Evercoat).  Used it under my Kury trans covers on both Valks for sound deadening.  Never thought of putting under the alt cover.  Still have the original alt cover on my Std, looks new.  Replaced the one on my I/S under warranty 12 years ago, still no bubbles.  Sitting on 3 new alt covers I got from Europe @ $17 ea.   Couldn't pass that up.  (they are Not for sale)   Wink
States I Have Ridden In
Steve K (IA)
Cedar Rapids, Iowa
« Reply #8 on: April 23, 2016, 04:52:50 PM »
Dan
I wouldn't think it would make a difference.
