February 11, 2026, 07:00:31 PM
Rear Brake Caliper?
Topic: Rear Brake Caliper? (Read 951 times)
pocket aces
Tampa, Fl
Rear Brake Caliper?
April 22, 2016, 09:51:15 AM »
Are all rear brake calipers the same for all 3 models? I thought they were. I looked on Partzilla and it looks like they have 2 types a 43150MT8305 & 43150MZ0006
They go by gl1500 SE AC, gl1500 CT AC, gl1500C AC ETC... Confused
I have a 2000 Interstate When I get home I'll check my model sticker.
Re: Rear Brake Caliper?
April 22, 2016, 01:13:29 PM »
The IS caliper is black, the other s are silver/grey. Other than that I think they are the same.
Bubba FoSho
April 22, 2016, 03:11:37 PM »
The rear brake caliper is wider than the two front brake calipers.. I use rear OEM brake pads on the front of my bike because they are thicker and they last longer.
April 22, 2016, 05:33:55 PM »
SE is most likely a GW.
The second letter is most likely the 49 State, and the Calif State, models.
C - Std
CT - Tourer
CF - IS
April 22, 2016, 06:18:58 PM »
The Interstate caliper has smaller pistons... whether it would bolt
onto a STD/Tourer and work, I don't know... I wish I had tried, but
when I saw that it was different, I didn't try...
PAVALKER
Pittsburgh, Pa
April 22, 2016, 07:19:15 PM »
Quote from: pocket aces on April 22, 2016, 09:51:15 AM
Are you in need of a rear caliper or ??
John
Jack B
Two Rivers Wis
Reply #6 on:
April 23, 2016, 06:15:47 AM »
I have a rear caliper from a 1997 if that helps you out.
Let’s RIDE
Reply #7 on:
April 23, 2016, 07:08:12 AM »
Quote from: Jack B on April 23, 2016, 06:15:47 AM
If its an IS caliper they are looking for I do not believe any Interstates were made in '97. I do have an IS rear caliper that can be had for shipping
