December 19, 2025, 10:49:51 PM
Florida Chapter
turn signal help
Topic: turn signal help (Read 1297 times)
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
turn signal help
April 24, 2016, 06:01:10 PM »
I posted this on the 1500 tech board also.
the right side works.
The left turn signal lights are staying on (not blinking) and so is the turn signal indicator on the headlight bucket. Both the front and rear bulbs are burning much brighter than the running light on the right side. I have the switch apart and cleaned with contact cleaner but no change.
I have replaced front and rear bulbs on the left side still no change.
FYI the right side blinks and the indicator blinks before the blinker, not in unison.
Any ideas on where to look,
Tony
If you please God it doesn't matter who you displease but if you displease God it doesn't matter who you please
Thunderbolt
Worthington Springs FL.
Re: turn signal help
April 25, 2016, 05:39:29 AM »
Ground problems usually result in weird lighting situations. Check all your grounds where they are attached to the frame. Follow the wiring from the turn signals back to the wiring loom under the right side cover and unplug and reattach all the connectors. It probably has nothing to do with the switch.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
April 25, 2016, 04:04:10 PM »
Thanks Thunderbolt tried that aand no change. blinker relay clicks when right blinker is on, but nothing when left side is on. Going to remove rear fender and check the wiring under there. ordered a new relay too.
Thunderbolt
April 25, 2016, 04:20:53 PM »
There is a connector there under the rear fender as you said. Clean up those connections by "exercising" it a few times. If memory serves me correctly the turn signal relay is behind the center cover, could be wrong on the location.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
April 25, 2016, 06:52:24 PM »
Found a couple wires that had bare spots seems that the car tire might have hit it. Put some electrical tape on and turned key on and blinker started blinking then nothing. Might have blown a fuse, it had a 15 in there and I changed it back to a 10. Going to check tomorrow after work.
Thanks for your help,
Tony
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
April 27, 2016, 12:36:48 PM »
10amp fuse was blown replaced with a 15amp works fine, I guess the PO upgraded when he added the rear running lights.
GOOD to GOOOOOOOO
Thanks for the help,
Wewa
Thunderbolt
Reply #6 on:
April 29, 2016, 03:35:39 AM »
Glad you got it going. Ride safe.
=> InZane XXV
