August 27, 2025, 01:01:38 PM
Desmog
Topic: Desmog (Read 769 times)
mikeb311978
Desmog
April 28, 2016, 11:26:33 PM »
Hey guys just wandering what the benifits of de smoging are my bike runs fine now but would like more input I have stock pipes that were Ragnar cut when I got it. Running a kn filter with pre filter other than that it's stock I believe except for the darkside mod which I just took on would like a little more performance without a lot of cost if possible?
Re: Desmog
April 29, 2016, 04:26:49 AM »
desmog will get you nothing, unless it coincidentally fixes
a vacuum leak.
-Mike "sorry about the ragnar cut
peter
Bethesda, Maryland
Re: Desmog
April 29, 2016, 07:01:21 AM »
In my view, the benefit of a desmog is that you eliminate most sources of potential vacuum leaks which becomes more of an issue as the bike ages. It also greatly simplifies pulling the carbs should you have to do that down the line, and it looks better with the pair valve and associated plumbing removed.
To me it's a nice-to-have mod, particularly if you work on your bike yourself. But there is no impact on performance what so ever.
Peter
desmogged '98
'98 Valk
'56 BSA
'04 Ducati
Re: Desmog
April 29, 2016, 08:42:27 AM »
All the above is true, but you can expect the vacuum caps on the intake nipples to self destruct every few years, apparently.
Steve K (IA)
Cedar Rapids, Iowa
Re: Desmog
April 29, 2016, 01:17:14 PM »
Don't "fix" what isn't broken.
States I Have Ridden In
john
tyler texas
Re: Desmog
April 29, 2016, 04:26:25 PM »
pull the trigger on the desmog ....
vrcc # 19002
big poppa pump
San Antonio, TX
Re: Desmog
Reply #6 on:
April 29, 2016, 07:57:45 PM »
Quote from: john on April 29, 2016, 04:26:25 PM
What he said!
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
=> InZane XXV
