August 27, 2025, 12:47:40 PM *
Author Topic: Higher mileage Valks owners........  (Read 1050 times)
spongebob
Alabama
« on: May 01, 2016, 06:53:21 PM »
Got 165K on bike. Getting ready to order parts to replace timing belts.....
Question is when have you changed the (belt tensioner) (ignition pulse generator) (timing belt adjustment spring).....Has anybody found bad bearings in the belt tensioner? Thanks for input..... Alvan crazy2
« Reply #1 on: May 01, 2016, 08:28:41 PM »
I just replaced the belts at 110k on Deerslayer.  The other parts showed no wear with no runout or play in the bearings. The ignition pulse either works or doesn't - it's digital. The spring seamed fine to me.
« Reply #2 on: May 01, 2016, 08:33:33 PM »
First, you don't want to order the belts from Honda. Go to NAPA or other auto parts store and get some Gates belts, same product supplied to Honda and less than half the price.
http://www.jkozloski.com/generic_parts.htm
As for the other questions, I've only heard of 2-3 cases of bad tensioners. Same for the springs. I've never heard of a bad pulse generator although I'm certain it has happened. All that stuff falls in the category of if it isn't broke, don't fix it. I've seen both Wings and Valkyries with triple or more your mileage with all those parts original except for the belts.
Simmy74
Lapeer Mi
« Reply #3 on: May 01, 2016, 11:01:25 PM »
Changed belts and swapped in OEM tensioners at 135k 99 I/S due to a Shrillary under acceleration load.  Springs and pulse sensors looked perfect.
Tensioners had the normal buildup around  the contact surface and one looked like the internal grease was starting to change it's mind.
Easy job, just be patient and don't be afraid to rotate the crank several cycles to make sure the timing marks line up before and after.  The peace of mind and "check twice, twice" is free once your in there.   I DIDN'T pull the plugs BTW, didn't have a problem turning the crank
Guns don't kill people.   Drivers with cellphones do.
Mr.BubblesVRCCDS0008
« Reply #4 on: May 02, 2016, 03:24:10 PM »
My bike has 197000 miles on it. Changed the belts about 110k.. nothing else was changed. I did take the time to adjust the valves. Really just checked them as only one or two neede a slight adjustment.
spongebob
Alabama
« Reply #5 on: May 02, 2016, 06:41:48 PM »
Thanks for your input......Alvan.. crazy2
DK
Little Rock
« Reply #6 on: May 03, 2016, 04:18:01 AM »
Do the springs set the proper belt tension?
It seems to me that the spring tension before tightening the tensioner so is pretty close if not correct.
O-B-1
Vancouver, WA
« Reply #7 on: May 03, 2016, 09:21:26 AM »
+1. AND the Gates belts come with the Honda OEM part number on the box, at least the ones I bought from RockAuto.com did... Man, they were only like $14 apiece.
David W. Mitchell
1999 Honda Valkyrie GL1500C
