February 11, 2026, 08:51:00 PM
drive shaft removal
Topic: drive shaft removal (Read 1076 times)
slider
mulberry arkansas
drive shaft removal
May 02, 2016, 07:20:57 PM »
AM going to service pinion gear drvie shaft and differential for the first time myself.Question when I pull the drive shaft do I remove the rubber boot as well,or will the shaft come out of it without removing the boot?Thanks
a proud navy veteran
Red Diamond
Beaumont, Texas
Re: drive shaft removal
May 02, 2016, 07:35:21 PM »
Hope I'm remembering correctly, it will come out without removing the boot. Of course you can apply grease easier at the u-joint if you remove the boot.
May 02, 2016, 07:36:25 PM »
When you unbolt the final drive and pull it off the drive shaft will be attached. You don't need to touch the boot
May 02, 2016, 07:40:37 PM »
Quote from: Chrisj CMA on May 02, 2016, 07:36:25 PM
+1 and when you pul the shaft from the final drive just pull straight out on it, it don't feel like it will come out but just keep pulling straight out
doubletee
VRCC # 22269
Fort Wayne, IN
May 04, 2016, 09:25:35 AM »
Here's a great video about how to remove the drive shaft from the final drive by one of the best Valk wrenches around, Big BF:
https://www.facebook.com/BigBF5/videos/576331115809274/
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
May 04, 2016, 10:12:20 AM »
Quote from: doubletee on May 04, 2016, 09:25:35 AM
I was looking for Big BF's video and couldn't find it to post. Your link didn't work for me tho
doubletee
VRCC # 22269
Fort Wayne, IN
Reply #6 on:
May 04, 2016, 01:11:43 PM »
Quote from: KY,Dave (AKA Misunderstood) on May 04, 2016, 10:12:20 AM
dunno. Maybe one needs to be "friends" with Big BF on Facebook in order to access it. I'll work on getting it a different way. Maybe it's on YouTube.
