February 11, 2026, 08:51:03 PM *
Author Topic: kuryakyn iso grip throttle removal help.  (Read 772 times)
98 VALK
« on: May 04, 2016, 05:20:27 PM »
I had these grips put on about 5 years ago & they are pitted and coming apart. I got the left side off no problemb. But the throttle side is really tight & i don't want to break the plastic throttle assy part. What is the best way to get these off. I thought about splitting it with a dremel tool down the center & trying to peel it off. Any help would be appreciated.  Thanks.
« Reply #1 on: May 04, 2016, 05:34:12 PM »
Shove a long skinny screwdriver under it or an ice pick, then squirt large amounts of regular rubbing alcohol in there. Try to do it in more than one spot.
98 VALK
« Reply #2 on: May 04, 2016, 06:20:50 PM »
I'll try it thanks.
« Reply #3 on: May 04, 2016, 06:30:34 PM »
Air compressor and blow air under it with a fine tip Nozzle and it will slide off in seconds.
« Reply #4 on: May 04, 2016, 07:49:47 PM »
That too, I used both....alcohol then the air. Shot that sucker clear across the garage.  Grin
Ramie
2001 I/S St. Michael MN
« Reply #5 on: May 05, 2016, 05:49:08 AM »
WD-40 also does the trick.
