February 11, 2026, 10:24:43 PM *
Author Topic: Truck stacks  (Read 1076 times)
Mike in AR
Redfield, Arkansas 72132
« on: May 09, 2016, 08:46:16 AM »
I have a 2000 I/S with a Motor Trike kit on it . It had glass packs on it, which I removed and will replace with a set of stock pipes. I need to put some truck stacks on them to extend them past the back edge of the kit. What size pipe do I need to put on and where can I purchase them. What I mean by what size is: 4" ID or 4" OD.  Thank you for any help you might be able to give.
« Last Edit: May 09, 2016, 09:55:46 AM by Mike in AR » Logged
Do not dwell in the past, do not dream of the future, concentrate the mind on the present moment.
Roidfingers
Tuscaloosa, Alabama
« Reply #1 on: May 09, 2016, 11:51:20 AM »
ID refers to inside diameter. OD refers to outside diameter.
« Reply #2 on: May 09, 2016, 12:07:48 PM »
they have exactly what u need
http://www.airflo.com/valkyrie.html
Mike in AR
« Reply #3 on: May 09, 2016, 12:34:13 PM »
Thanks 98valk, That's just what I was looking for. Appreciate it a bunch.
DK
Little Rock
« Reply #4 on: May 09, 2016, 12:36:07 PM »
Mike,
Is this the trike Mitch had?
I extended the exhausts on mine last year with 20" long, 4" lengths of galvanized truck exhaust pipe with the stock tips attached to the ends.  The piggies were extended with 3/4" copper tube and the 4" pipe was cheesecaked with 2" holes to lighten it.
It's not necessary to extend the piggies, although there seems to be a debate as to droning without the extensions.
My project and other similar ones are discussed at:
http://www.valkyrieforum.com/bbs/index.php/topic,84057.0.html
Call me & I'll help you with the project. I've got welders, drill presses etc. needed for the job. We can do it in an afternoon.
Dan
